- To: ,
- Subject: [cgal-discuss] CGAL bug-fix release CGAL 4.14.3 and 5.0.2
- Date: Tue, 25 Feb 2020 13:27:56 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
The CGAL Open Source Project is pleased to announce the releases 4.14.3 and
5.0.2 of CGAL, the Computational Geometry Algorithms Library.
These are bug-fix releases. The list of bugs that were solved since 4.14.2
and
5.0.1, respectively, can be found on Github:
https://github.com/CGAL/cgal/releases/tag/releases/CGAL-5.0.2
https://github.com/CGAL/cgal/releases/tag/releases/CGAL-4.14.3
Laurent Rineau, PhD
- [cgal-discuss] CGAL bug-fix release CGAL 4.14.3 and 5.0.2, Laurent Rineau (CGAL/GeometryFactory), 02/25/2020
