- To:
- Subject: Re: [cgal-discuss] CGAL- Is there a method for manifold mesh?
- Date: Tue, 25 Feb 2020 21:41:41 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Actually, to double covered mesh, it may not be necessary to actually change
the position of the points (such as moving along the normal line of the
face: I put an example here which moves the position of the points:
<http://cgal-discuss.949826.n4.nabble.com/file/t376165/2.jpg> ), but simply
to duplicate one or more such points.
Many thanks for your kind help and guidance.
be open, be creative, be critical
- [cgal-discuss] CGAL- Is there a method for manifold mesh?, Frank Dz, 02/18/2020
- Re: [cgal-discuss] CGAL- Is there a method for manifold mesh?, Mael, 02/25/2020
- Re: [cgal-discuss] CGAL- Is there a method for manifold mesh?, Frank Dz, 02/26/2020
