- To:
- Subject: Re: [cgal-discuss] Exact closest neighbor not working correctly
- Date: Fri, 17 Apr 2020 19:51:57 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:PGrCWR0e5vnBo+2csmDT+DRfVm0co7zxezQtwd8ZsegXI/ad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6an3up8DRHGgnjLREnYaPuC4vKhoK20fqz8tvdeUJTlT+laPRzKhux6g7ev81TjYp5Ibsq0Uj1pS5DdO1SgG9pPlmOhA3U58Gq/Zcl/T4Dlegm8ptiTKz8N4Y/VrEQJz09Om4v7cvgvFGXTwmE72AZW38+nR9BAgyD5xb/CMSi+hDmv/ZwjXHJdfb9Sqo5DGz7vvVbDSTwgSJCDAYXtWTei8h+lqVe+UvzqBl2woqSa4aQZqMnI/HtOOgCTG8EZf5/EixMBoTmMtkKBusFePhD9szz+wFIohy5Cg2hQujoz20Q3yOk7egBy+0kVDr+8kk4BdtX6Sbbqdz0MOEZVuXnlKQ=
Sure, find attached a minimal example and the data I am using.
Thanks
Could you please provide a minimal example that we could compile, run
and that would be showing the error?
At first sight, I don't see anything suspicious.
Thanks,
Sebastien.
On 4/17/20 6:25 PM, Juan Jose Casafranca wrote:
> I am trying to find the closest neighbor in a point cloud to a given
> point. I have followed the documentation example in which the points are
> stored in a user vector and the Tree only contains indices. Since the
> results were not what I was expecting, I am also computing the closest
> neighbor by brute force. Ill explain my code:
> I have a vector of points (coarsePoints) and I have a vector of indices
> (xC_vertices). The indices are the points in coarsePoints that can be
> marked as closest neighbor.
> This is how I compute the closest point using a brute force algorithm
> for (int i = 0; i < d_vertices.size(); ++i) {
> Real minDistance = std::numeric_limits<Real>::infinity();
> int vertexId = -1;
> const auto &dPoint = highResPoints[d_vertices[i]];
> const CPF::Point_3 pD{dPoint[0], dPoint[1], dPoint[2]};
> for (int j = 0; j < xC_vertices.size(); ++j) {
> const auto &xPoint = coarsePoints[xC_vertices[j]];
> const CPF::Point_3 pC{xPoint[0], xPoint[1], xPoint[2]};
> if (CGAL::squared_distance(pC, pD) < minDistance) {
> vertexId = j;
> minDistance = CGAL::squared_distance(pC, pD);
> When using CGAL, I have the following (based on the documentation example):
> class My_point_property_map
> const sofa::helper::vector<CPF::SofaTypes::Point> &points;
> const std::vector<CPF::SofaTypes::Tetra::value_type> &xC_vertices;
> public:
> typedef CPF::Point_3 value_type;
> typedef value_type &reference;
> typedef std::size_t key_type;
> typedef boost::lvalue_property_map_tag category;
> My_point_property_map(const sofa::helper::vector<CPF::SofaTypes::Point>
> &pts,
> const std::vector<CPF::SofaTypes::Tetra::value_type> &xC_vertices_)
> : points(pts)
> , xC_vertices(xC_vertices_)
> value_type operator[](key_type k) const
> const CPF::SofaTypes::Point &sPoint = points[xC_vertices[k]];
> return CPF::Point_3{sPoint[0], sPoint[1], sPoint[2]};
> friend value_type get(const My_point_property_map &ppmap, key_type i) {
> return ppmap[i]; }
> using SearchTraitsBase = CGAL::Search_traits_3<CPF::K>;
> using SearchTraits = CGAL::Search_traits_adapter<std::size_t,
> My_point_property_map, SearchTraitsBase>;
> using NeighborSearch = CGAL::Orthogonal_k_neighbor_search<SearchTraits>;
> using Tree = NeighborSearch::Tree;
> using Splitter = typename Tree::Splitter;
> using SearchDistance = typename NeighborSearch::Distance;
> int searchNeighbor() {
> My_point_property_map ppmap(coarsePoints, xC_vertices);
> Tree searchTree(boost::counting_iterator<int>(0),
> boost::counting_iterator<int>(xC_vertices.size()),
> Splitter(),
> SearchTraits(ppmap));
> SearchDistance trDistance(ppmap);
> NeighborSearch search(searchTree, CPF::Point_3{dPoint[0], dPoint[1],
> dPoint[2]}, 1, 0, true, trDistance);
> for (const auto &searchResult : search) {
> if (searchResult.first != vertexId) {
> spdlog::get("cpf")->info("Brute force id = {}", vertexId);
> spdlog::get("cpf")->info("CGAL id = {}", searchResult.first);
> spdlog::get("cpf")->info("Brute force distance = {}", minDistance);
> spdlog::get("cpf")->info("CGAL distance = {}", searchResult.second);
> This return a los of vertices that are actually different:
> [2020-04-17 18:10:31.988] [cpf] [info] Brute force id = 386
> [2020-04-17 18:10:31.988] [cpf] [info] CGAL id = 84
> [2020-04-17 18:10:31.988] [cpf] [info] Brute force distance = 0.0
> [2020-04-17 18:10:31.988] [cpf] [info] CGAL distance = 0.041339367896971506
> I am not sure if I am using incorrectly the NeighborSearch or what is
> happening. Any ideas what might be wrong?
#include <CGAL/Simple_cartesian.h> #include <CGAL/Orthogonal_k_neighbor_search.h> #include <CGAL/Search_traits_3.h> #include <CGAL/Search_traits_adapter.h> #include <boost/iterator/counting_iterator.hpp> #include <CGAL/AABB_face_graph_triangle_primitive.h> #include <CGAL/AABB_tree.h> #include <CGAL/AABB_traits.h> #include <CGAL/Polygon_mesh_processing/locate.h> #include <CGAL/Polygon_mesh_processing/triangulate_faces.h> #include <fstream> using Real = double; using K = CGAL::Simple_cartesian<Real>; using Point_3 = K::Point_3; using MyPoint = std::array<Real, 3>; using PointId = unsigned int; class My_point_property_map { const std::vector<MyPoint> &points; const std::vector<PointId> &xC_vertices; public: typedef K::Point_3 value_type; typedef value_type &reference; typedef std::size_t key_type; typedef boost::lvalue_property_map_tag category; My_point_property_map(const std::vector<MyPoint> &pts, const std::vector<PointId> &xC_vertices_) : points(pts) , xC_vertices(xC_vertices_) { } value_type operator[](key_type k) const { const MyPoint &sPoint = points[xC_vertices[k]]; return Point_3{sPoint[0], sPoint[1], sPoint[2]}; } friend value_type get(const My_point_property_map &ppmap, key_type i) { return ppmap[i]; } }; using SearchTraitsBase = CGAL::Search_traits_3<K>; using SearchTraits = CGAL::Search_traits_adapter<std::size_t, My_point_property_map, SearchTraitsBase>; using NeighborSearch = CGAL::Orthogonal_k_neighbor_search<SearchTraits>; using Tree = NeighborSearch::Tree; using Splitter = typename Tree::Splitter; using SearchDistance = typename NeighborSearch::Distance; int main() { std::vector<PointId> d_vertices; std::vector<PointId> xC_vertices; std::vector<MyPoint> coarsePoints; std::vector<MyPoint> highResPoints; std::ifstream str; str.open("/tmp/test.bin", std::istream::binary); std::size_t coarsePointsSize; std::size_t highResPointsSize; std::size_t xC_verticesSize; std::size_t d_verticesSize; str >> coarsePointsSize; coarsePoints.resize(coarsePointsSize); str.read(reinterpret_cast<char *>(coarsePoints.data()), sizeof(MyPoint) * coarsePoints.size()); str >> highResPointsSize; highResPoints.resize(highResPointsSize); str.read(reinterpret_cast<char *>(highResPoints.data()), sizeof(MyPoint) * highResPoints.size()); str >> xC_verticesSize; xC_vertices.resize(xC_verticesSize); str.read(reinterpret_cast<char *>(xC_vertices.data()), sizeof(unsigned int) * xC_vertices.size()); str >> d_verticesSize; d_vertices.resize(d_verticesSize); str.read(reinterpret_cast<char *>(d_vertices.data()), sizeof(unsigned int) * d_vertices.size()); My_point_property_map ppmap(coarsePoints, xC_vertices); Tree searchTree(boost::counting_iterator<int>(0), boost::counting_iterator<int>(xC_vertices.size()), Splitter(), SearchTraits(ppmap)); SearchDistance trDistance(ppmap); for (int i = 0; i < d_vertices.size(); ++i) { Real minDistance = std::numeric_limits<Real>::infinity(); int vertexId = -1; const auto &dPoint = highResPoints[d_vertices[i]]; const Point_3 pD{dPoint[0], dPoint[1], dPoint[2]}; for (int j = 0; j < xC_vertices.size(); ++j) { const auto &xPoint = coarsePoints[xC_vertices[j]]; const Point_3 pC{xPoint[0], xPoint[1], xPoint[2]}; const auto distance = trDistance.transformed_distance(pD, j); if (distance < minDistance) { vertexId = j; minDistance = distance; } } NeighborSearch search(searchTree, Point_3{dPoint[0], dPoint[1], dPoint[2]}, 1, 0.0001, true, trDistance); for (const auto &searchResult : search) { if (searchResult.first != vertexId) { std::cout << "Brute force id = " << vertexId << "\n"; std::cout << "CGAL id = " << searchResult.first << "\n"; std::cout << "Brute force distance = " << minDistance << "\n"; std::cout << "CGAL distance = " << searchResult.second << "\n"; } } } }
test.bin
Description: Binary data
- [cgal-discuss] Exact closest neighbor not working correctly, Juan Jose Casafranca, 04/17/2020
- Re: [cgal-discuss] Exact closest neighbor not working correctly, Sebastien Loriot (GeometryFactory), 04/17/2020
- Re: [cgal-discuss] Exact closest neighbor not working correctly, Juan Jose Casafranca, 04/17/2020
- Re: [cgal-discuss] Exact closest neighbor not working correctly, Marc Glisse, 04/17/2020
- Re: [cgal-discuss] Exact closest neighbor not working correctly, Lokesh Kumar, 04/18/2020
- Re: [cgal-discuss] Exact closest neighbor not working correctly, Marc Glisse, 04/18/2020
- Re: [cgal-discuss] Exact closest neighbor not working correctly, Juan Jose Casafranca, 04/20/2020
