Re: [cgal-discuss] CGAL::difference for 2d polygon return a incorrect result polygon
- To:
- Subject: Re: [cgal-discuss] CGAL::difference for 2d polygon return a incorrect result polygon
- Date: Sun, 26 Apr 2020 14:00:12 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Please provide a simple test case, nicely indented, using only point type from EPEC (exact predicates exact constructions), that can be used to reproduce the problem.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
Hi,
I'm newer to use cgal, I want to split the given polygon by another
polygon. Then I choose the CGAL::difference function. But in some cases,
it's function return incorrect result polygon for me.
Here is my code:
// TArray is a template for an array, FVector2D is a struct for a 2d point,
use float number type.
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Boolean_set_operations_2.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Polygon_with_holes_2.h>
#include <CGAL/Polygon_set_2.h>
#include <list>
typedef CGAL::Exact_predicates_exact_constructions_kernel exactKernel;
typedef exactKernel::Point_2 exactPoint_2;
typedef CGAL::Polygon_2<exactKernel> exactPolygon_2;
typedef CGAL::Polygon_with_holes_2<exactKernel>
exactPolygon_with_holes_2;
typedef CGAL::Polygon_set_2<exactKernel>
exactPolygon_set_2;
typedef exactKernel::Segment_2 exactSegment_2;
typedef exactKernel::Vector_2 exactVector_2;
void UPaveMethodFunctionLibrary::FiltrationPolygon(const
TArray<FPolygonData>& InHolesPolygon, TArray<FVector2D>&
OutFiltrationPolygon)
if (OutFiltrationPolygon.Num() < 3 || InHolesPolygon.Num() == 0){
return;
exactPolygon_2 targetPolygon;
std::list<exactPolygon_2> holesPolygon;
for (int32 filtrationPolygonIndex = 0; filtrationPolygonIndex <
OutFiltrationPolygon.Num(); ++filtrationPolygonIndex)
targetPolygon.push_back(exactPoint_2(OutFiltrationPolygon[filtrationPolygonIndex].X,
OutFiltrationPolygon[filtrationPolygonIndex].Y));
if (targetPolygon.is_clockwise_oriented()) {
targetPolygon.reverse_orientation();
for (int32 holePolygonIndex = 0; holePolygonIndex < InHolesPolygon.Num();
++holePolygonIndex)
exactPolygon_2 currentHolePolygon;
for (int32 holePointIndex = 0; holePointIndex <
InHolesPolygon[holePolygonIndex].Polygon.Num(); ++holePointIndex)
currentHolePolygon.push_back(exactPoint_2(InHolesPolygon[holePolygonIndex].Polygon[holePointIndex].X,
InHolesPolygon[holePolygonIndex].Polygon[holePointIndex].Y));
if (currentHolePolygon.is_clockwise_oriented()) {
currentHolePolygon.reverse_orientation();
holesPolygon.push_back(currentHolePolygon);
bool IsExistInList = false;
std::list<exactPolygon_2> tempholesPolygon;
for (std::list<exactPolygon_2>::const_iterator holePolygonListIt =
holesPolygon.cbegin(); holePolygonListIt != holesPolygon.cend();
++holePolygonListIt)
for (exactPolygon_2::Edge_const_iterator holePolygonIt =
holePolygonListIt->edges_begin(); holePolygonIt !=
holePolygonListIt->edges_end(); ++holePolygonIt)
for (exactPolygon_2::Edge_const_iterator targetPolygonIt =
targetPolygon.edges_begin(); targetPolygonIt != targetPolygon.edges_end();
++targetPolygonIt)
if (targetPolygonIt->collinear_has_on(holePolygonIt->start()) &&
targetPolygonIt->collinear_has_on(holePolygonIt->end()))
IsExistInList = true;
tempholesPolygon.push_back(*holePolygonListIt);
break;
if (IsExistInList){
break;
if (tempholesPolygon.size() == 0){
return;
for (exactPolygon_2 currentHolePolygon : tempholesPolygon)
std::list<exactPolygon_with_holes_2> differencePolygons;
CGAL::difference(targetPolygon, currentHolePolygon,
std::back_inserter(differencePolygons));
if (differencePolygons.size() != 1) {
return;
targetPolygon = differencePolygons.front().outer_boundary();
if (targetPolygon.size() < 3 || !targetPolygon.is_simple()){
return;
OutFiltrationPolygon.Empty();
for (exactPolygon_2::Vertex_const_iterator it =
targetPolygon.vertices_begin(); it != targetPolygon.vertices_end(); it++)
double pointX = CGAL::to_double(it->x());
double pointY = CGAL::to_double(it->y());
OutFiltrationPolygon.AddUnique(FVector2D(pointX, pointY));
- [cgal-discuss] CGAL::difference for 2d polygon return a incorrect result polygon, Luoyu, 04/26/2020
- Re: [cgal-discuss] CGAL::difference for 2d polygon return a incorrect result polygon, Efi Fogel, 04/26/2020
