cgal-discuss - Re: [cgal-discuss] Trouble compiling surface_mesh example using cmake-gui (Ubuntu)
  • To:
  • Subject: Re: [cgal-discuss] Trouble compiling surface_mesh example using cmake-gui (Ubuntu)
  • Date: Thu, 30 Apr 2020 09:20:16 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
At GeometryFactory we use development branches and master, so we use git, not the package manager.
Le jeu. 30 avr. 2020 à 03:38, Trần Anh <> a écrit :
Ah I see.
What is the normal practice at GeometryFactory or other company that relies on CGAL? Are they taking advantage of the package manager or did they download the source code and then set CGALDIR and some other cmake variables themselves?
Thanks & Regards
Anh Tran
Be careful what version of CGAL it gives you, though. I see it is 4.7 on Xenial,and 5.0 is only on focal (Ubuntu 20 I think).  You should probably download the whole release and use it directly, instead of trying to use examples from a different version.
Le mer. 29 avr. 2020 à 15:16, Maxime Gimeno <> a écrit :
I see it depends on libcgal-dev, so it must be just an extension.
Le mer. 29 avr. 2020 à 14:57, Trần Anh <> a écrit :
Thanks Maxime,
Will I need to uninstall libcgal-dev before doing so? Is this like an extension to libcgal-dev or is this libcgal-dev + qt5 component?
I think you should install libcgal-qt5-dev then.
Le mer. 29 avr. 2020 à 14:33, Trần Anh <> a écrit :
Hi,
I just followed the CGAL's getting started guide: sudo apt-get install libcgal-dev
I have compiled and run CGAL program in the past but for some reason I decided to not use Qt5 or create_single_source_cgal_program. I used add_executable and it has always worked fine. But now I would like to ultilise CGAL's integrated graphic library to speed up my work.
Thanks & Regards
Anh Tran
Hi,
Can you tell us  the name of the package you installed ?
Le mer. 29 avr. 2020 à 14:21, anh.tran <> a écrit :
Hi,
I have this problem when compiling surface_mesh example using cmake-gui:
The C compiler identification is GNU 7.5.0
The CXX compiler identification is GNU 7.5.0
Check for working C compiler: /usr/bin/cc
Check for working C compiler: /usr/bin/cc -- works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Detecting C compile features
Detecting C compile features - done
Check for working CXX compiler: /usr/bin/c++
Check for working CXX compiler: /usr/bin/c++ -- works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Detecting CXX compile features
Detecting CXX compile features - done
NOTICE: The CGAL_Qt5 library was not configured. CGAL was configured with
WITH_CGAL_Qt5=ON, but one of the dependencies of CGAL_Qt5 was not configured
properly.
CMake Error at CMakeLists.txt:29 (create_single_source_cgal_program):
  Unknown CMake command "create_single_source_cgal_program".
Configuring incomplete, errors occurred!
See also
"/home/anhtran/Desktop/Programming/CGAL-5.0.2_example/examples/Surface_mesh/build/CMakeFiles/CMakeOutput.log".
I installed CGAL through apt-get so everything is in the default folder
(/usr/lib/x86_64-linux-gnu/cmake/CGAL). My main concern here is the command
"create_single_source_cgal_program" is not recognised, but you can also see
that I also having trouble getting Qt5 to work probably (NOTICE: The
properly).
I have not modified the CMakeLists.txt file.
Help a learner out? Thank you.
Thanks & Regards
Anh Tran
