cgal-discuss - [cgal-discuss] Minkowski Sum (exact offset) with General Polygons
  • To:
  • Subject: [cgal-discuss] Minkowski Sum (exact offset) with General Polygons
  • Date: Tue, 26 May 2020 15:10:03 +0000 (UTC)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
With CGAL 5.0.2, is it possible to perform an exact offset on a General Polygon?
I've been examining the Minkowski examples and digging into the source code. I can generate a General polygon (based on conic arcs) from a simple unit square polygon (with straight edges). If I have a "rounded rectangle" that is defined as a general polygon with straight and curved segments - can I perform an exact offset on this rounded rectangle to obtain a larger rounded rectangle? I don't see anything in the source that allows this (or at least I couldn't understand how to do it while satisfying the templates).
Thanks to anyone who can help and advise me.
