- To:
- Subject: Re: [cgal-discuss] STEP and NURBS
- Date: Tue, 9 Jun 2020 09:06:57 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
CGAL can read STL files and build surface meshes. There are many
operations then available. What are you looking for?
About parametric surfaces, there is nothing in CGAL but I guess
it should be possible to write a domain class to mesh them if you
know how to compute the intersection with a segment.
Best regards,
Sebastien.
On 5/27/20 9:03 AM, John ( via cgal-discuss Mailing List) wrote:
Dear Laurent,
Many thanks for your prompt and sharp answer.
Well, I wish it would have been more... positive !
I need to handle, as input file, one of the CAD standard file format.
Would STL file format be supported by CGAL ?
OK, it's also understood that CGAL cannot deal with NURBS.
What about parametric surfaces (that do NOT rely on Bezier curves) ?
Thanks John
- Re: [cgal-discuss] STEP and NURBS, Sebastien Loriot (GeometryFactory), 06/09/2020
