cgal-discuss - Re: [cgal-discuss] How to use Kernel_traits?
  • To:
  • Subject: Re: [cgal-discuss] How to use Kernel_traits?
  • Date: Sun, 9 Aug 2020 23:07:13 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
If you look at the documentation of Kernel_traits (https://doc.cgal.org/latest/Kernel_23/structCGAL_1_1Kernel__traits.html), you'll see that this traits class searches for a `R` typedef, which is the kernel. This `R` typedef exists for CGAL kernel objects (e.g. CGAL::Point_2, Point_3, etc.) but not for mesh types such as `Surface_mesh`.
What you would usually do here is to extract the point type from the mesh vertex->point property map of your mesh and call `Kernel_traits` on that point type, so something like:
    typedef typename property_map_value<Mesh, CGAL::vertex_point_t>::type Point;
typedef typename
CGAL::Kernel_traits<Point>::Kernel Kernel;
Note that this still assumes that your mesh is compatible with the BGL interface, which is valid for all meshes in CGAL and so more from other libraries, see https://doc.cgal.org/latest/BGL/index.html#title0. Furthermore, your `Point` type must be compatible with `Kernel_traits` (i.e. it defines a `R` typedef), otherwise you will need a partial specialization of `Kernel_traits`.
Best,
Mael
On 2020-08-09 14:00, Ben Laurie wrote:
I want to write a template function that does something to a mesh, but without assuming anything about how the mesh is defined (i.e. I don't know what the kernel is).
I thought I could do something like this:
template<class Mesh>
void someFn(const Mesh &m)
    typedef typename CGAL::Kernel_traits<Mesh>::Kernel Kernel;
    typedef typename Kernel::Point_3 Point;
but this gives me errors like:
      'CGAL::internal_kernel_traits::Dummy_kernel<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Epeck>
    typedef typename CGAL::Kernel_traits<Mesh>::Kernel::Point_3 Point;
What am I doing wrong?
