- To:
- Subject: Re: [cgal-discuss] Inconsistent output for Min_sphere_d
- Date: Thu, 20 Aug 2020 15:01:43 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
As a follow up I started this WIP pull request. https://github.com/CGAL/cgal/pull/4941
Best,
Andreas
On 8/20/2020 11:22 AM, Hoffmann Michael
wrote:
It is not really deprecated in the sense that we plan to remove it eventually, for the reasons given there. Best, Michael
On 20 Aug 2020, at 09:04, Raphael Grimm wrote: Thanks for the help! Using Min_sphere_of_spheres_d fixed this for me. I only skimmed the documentation and did not see the note. It would be nice if deprecated functions would be decorated with [[deprecated]] (c++14 feature). if macros are used, this can be done conditionally depending on the c++ standard. On 19.08.20 19:50, Hoffmann Michael wrote:See the quote from the docs below. Did you try sphere_of_spheres? Or Epeck? Best, Michael Please note: This class is (almost) obsolete. The class CGAL::Min_sphere_of_spheres_d<Traits> solves a more general problem and is faster then Min_sphere_deven if used only for points as input. Most importantly, CGAL::Min_sphere_of_spheres_d<Traits> has a specialized implementation for floating-point arithmetic which ensures correct results in a large number of cases (including highly degenerate ones). In contrast, Min_sphere_d is not reliable under floating-point computations. The only advantage of Min_sphere_d over CGAL::Min_sphere_of_spheres_d<Traits> is that the former can deal with points in homogeneous coordinates, in which case the algorithm is division-free. Thus, Min_sphere_d might still be an option in case your input number type cannot (efficiently) divide.On 19 Aug 2020, at 18:52, Raphael Grimm wrote: Hi, i was playing around with Min_sphere_d and encountered some behavior i do not understand (see attached files). In both cases my code creates a Min_sphere_d using Min_sphere_annulus_d_traits_3 and Epick and then it inserts three points and prints the radius. In the first case i used doubles to initialize the Point_3 and the output is correct. In the second case i used floats to initialize the Point_3 and the output is nan. The only difference is the type of the values used to initialize the Point_3. This means the error has to be caused by the differences in accuracy, but this should not really create a difference. Has anyone any idea why this happens and how i can prevent this problem? Since the data i am using is represented as floats, I can't really switch everything to double. I appreciate any help. Best regards, Raphael PS.: I am on master (54f2a119f9598f884f98df9ee1fa63aa07451c4c). -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss <code.cpp> <output>-- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss
-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Inconsistent output for Min_sphere_d, Raphael Grimm, 08/19/2020
- Re: [cgal-discuss] Inconsistent output for Min_sphere_d, Hoffmann Michael, 08/19/2020
- Re: [cgal-discuss] Inconsistent output for Min_sphere_d, Raphael Grimm, 08/20/2020
- Re: [cgal-discuss] Inconsistent output for Min_sphere_d, Hoffmann Michael, 08/20/2020
- Re: [cgal-discuss] Inconsistent output for Min_sphere_d, Andreas Fabri, 08/20/2020
