- To:
- Subject: [cgal-discuss] Crash when using mesh_plane_detection
- Date: Wed, 2 Sep 2020 14:11:51 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Load the .STL into the "polyhedron" demo , and select the "Mesh
Plane Detection" option, accepting defaults, results in a crash.
There is an out of bounds on a vector at the line 131 in Mesh_plane_detection_plugin.cpp
cylinder.zip
Description: Zip compressed data
- [cgal-discuss] Crash when using mesh_plane_detection, Andrew Cunningham, 09/02/2020
- Re: [cgal-discuss] Crash when using mesh_plane_detection, Andreas Fabri, 09/03/2020
