- To: "Frank Dz ( via cgal-discuss Mailing List)" <>
- Subject: Re: [cgal-discuss] Does power diagrams have differentiability?
- Date: Sun, 6 Sep 2020 14:32:24 +0200
Hi Frank,
To do that, you can proceed as follows:
1) write the equation of the coordinates of the circumcenter of a triangle in function of the coordinates of the three vertices of the triangle
2) compute their derivative
Using matrix derivation rules helps (https://tminka.github.io/papers/matrix/minka-matrix.pdf)
I did that in the following article (see in particular the appendix)
https://hal.inria.fr/inria-00600251/fr/
Hope this helps,
-- Bruno
How can we build up the connection between a vertex of the diagram and the
seed in Power Diagram?
Best,
Thanks
Frank
be open, be creative, be critical
- [cgal-discuss] Does power diagrams have differentiability?, Frank Dz, 09/06/2020
- Re: [cgal-discuss] Does power diagrams have differentiability?, Bruno Levy, 09/06/2020
- Re: [cgal-discuss] Does power diagrams have differentiability?, Frank Dz, 09/06/2020
- Re: [cgal-discuss] Does power diagrams have differentiability?, Marc Alexa, 09/08/2020
