- To:
- Subject: Re: [cgal-discuss] Same code - different compilation results
- Date: Thu, 10 Sep 2020 03:29:22 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Yes, i just discovered the issue is in the enabling of the Eigen macro.
thanks for helping!!
- [cgal-discuss] Same code - different compilation results, calvin_cw, 09/10/2020
- Re: [cgal-discuss] Same code - different compilation results, Andreas Fabri, 09/10/2020
- Re: [cgal-discuss] Same code - different compilation results, calvin_cw, 09/10/2020
