cgal-discuss - Re: [cgal-discuss] Minor documentation error
  • To:
  • Subject: Re: [cgal-discuss] Minor documentation error
  • Date: Mon, 28 Sep 2020 07:45:55 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Thanks for the heads-up. Fixed in https://github.com/CGAL/cgal/pull/5028
Le ven. 25 sept. 2020 à 23:22, Andrew Cunningham <> a écrit :
The text says " As in the BGL, named parameters in CGAL are also concatenated using the dot operator, and a typical usage is thus:"
The example does not show concatenation using a dot operator
