Re: [cgal-discuss] make_mesh_3 with manifold() specified outputing non-manifold mesh
- To:
- Subject: Re: [cgal-discuss] make_mesh_3 with manifold() specified outputing non-manifold mesh
- Date: Mon, 5 Oct 2020 18:38:33 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:3aluiRC4NW2O0U1zy1JGUyQJP3N1i/DPJgcQr6AfoPdwSPXypcbcNUDSrc9gkEXOFd2Cra4d1KyK6euxBSQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTagY75+Nhq7oRveusQSjoZpN7o8xAbOrnZUYepd2HlmJUiUnxby58ew+IBs/iFNsP8/9MBOTLv3cb0gQbNXEDopPWY15Nb2tRbYVguA+mEcUmQNnRVWBQXO8Qz3UY3wsiv+sep9xTWaMMjrRr06RTiu86FmQwLuhSwaNTA27XvXh9RtgqxbvhyhqR9xzYDab46aNvVxYqzTcMgGRWdCRMtdSzBND42+YoYJEuEPPfxYr474p1YWoxewGBejC/j1xT9Tmn/23LM10+I8Gg/A2wwgBdMOsHPIrN7oMKscUP66zK7NzTrdc/NWwzf85ojSfR89vfGMWqhwcMrUxUUhCgjIiU6QqYjiPzOP1+QNtHSb4/BlVeKrkGMnpARxrSKuxscokIXGmoUVylXd+Ch/3Y06KsG2RlRhbt64DJtfqTuaN41uT80iQWxkpiY0xqMYtZKlcyUHyYorygLRZvGbcoWF/A7uWfqRLzl2mH9pZb2yihW9/EWuy+DxWMe63VhEoydYj9XBsG0G2RLU6siCUPR9/0Gh1C6J1w/J8e5LOkQ0mrTBJ5E9xb4wk5weulnAEC/ugEj6krOae0E+9uWr6+nreKjqqoGfOoNuigzyL7wiltKlDugkLwQDWnaU9fim27Dm40H1XKhGg/g4n6bDrpzWOcEWqrC6DgJWzoku7hmyAC2839kcmHQLMVxIdRGdgIXsNVHDIvL1APW5jl+xijlk3erGMafkApjVLnjMjrPhfbFl5k5Z0gUzzNRf64taC7EEPf7/Q0HxudzFAhMjPAy0xOHnCNp51owAQ26AHqiZMKbKvV+J4OIgPfWMaZcLtDrhL/Up/f3jgH8jlVMAY6Wk3oEbZXClEvh+JkWWe3vsgtMPEWcQuQo+SfTniEaGUT5UfXayXqU85i0hBIKjCYfOXY+tgLmb0ye6Gp1afHxJCleJEXvwbYWLR+8MaD6OIs9mijELSbehRJUl1R23qQD6yqFnIfbJ+i0DrpLuz8N15u3WlREq7zN4FcWd02eXT2F1hGwEXTE23Los6XB6n1yM2Kw9j/1DHsFI/NtIVB07PNjS1b9UEdf3D0j6c92AU0qnT9PuJTYrT9Uti58hbkF4Fsm4nz7K1DatGa5U3fTfH5gz6KPbwz70I+5yzn/H0O8qiFxwEZgHDnGvmqMqr1ubPIXOiUjMz//7J5RZ5zbE8SK49UTLuUhZVABqVqCcBCIQY0LXqZLy4UaQFubzW4RiCRNIzIu5EoUPatDtig8bFvLqOdCbfGfo3mntXFCHwbSDaIescGIYjn2EVBo01jsL9HPDDjAQQz+7qjuHXjNrHFPrJUjr9LsmpQ==
I meant
std::ofstream("scaffold.off") << std::setprecision(17) << scaffold;
Sebastien.
On 10/5/20 6:04 PM, Sebastien Loriot (GeometryFactory) wrote:
Could you dump a problematic mesh and send it to me?
put right after the call to facets_in_complex_3_to_triangle_mesh()
std::ofstream("scaffold.off") << std::setprecision(17) scaffold;
Thanks!
Sebastien.
On 10/5/20 5:52 PM, Kim ( via cgal-discuss Mailing List) wrote:Hi everyone,
I am using make_mesh_3 to mesh an implicit domain and subsequently
extracting the surface triangulation, clipping it and doing some other
post-processing.
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Parallel_tag Concurrency_tag;
typedef CGAL::Polyhedron_3<Kernel, CGAL::Polyhedron_items_with_id_3>
PolygonMesh;
typedef CGAL::Labeled_mesh_domain_3<Kernel> Implicit_domain;
typedef CGAL::Mesh_triangulation_3<Implicit_domain, CGAL::Default,
Concurrency_tag>::type VTr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<VTr> C3t3;
typedef CGAL::Mesh_criteria_3<VTr> Mesh_criteria;
Implicit_domain domain = Implicit_domain::create_implicit_mesh_domain(
myImplicitFunction, boundBox);
Mesh_criteria criteria(CGAL::parameters::facet_angle = facetAngle,
CGAL::parameters::facet_size = facetSize,
CGAL::parameters::facet_distance = facetDistance);
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
CGAL::parameters::manifold())
PolygonMesh scaffold;
CGAL::facets_in_complex_3_to_triangle_mesh(c3t3, scaffold);
// Clip mesh
PolygonMesh outer_shell;
CGAL::Polygon_mesh_processing::polygon_soup_to_polygon_mesh(points,
polygons, outer_shell);
CGAL::Polygon_mesh_processing::remove_isolated_vertices(scaffold); //
Temporary fix to bug!!!
if( CGAL::Polygon_mesh_processing::clip(scaffold, outer_shell,
CGAL::parameters::clip_volume(true).use_compact_clipper(true)) == false)
std::cout << "\n WARNING: Scaffold and clipper have only been
corefined!" << std::endl;
// Remove all but the largest component
CGAL::Polygon_mesh_processing::keep_largest_connected_components(scaffold,
1);
// Reorient all faces coherently
if (CGAL::is_closed(scaffold) == true) {
CGAL::Polygon_mesh_processing::orient(scaffold,
CGAL::parameters::outward_orientation(true));
} else {
std::cout << "\n WARNING: Polygon has border edges!" << std::endl;
The problem I am experiencing is that although I have specified I want a
manifold mesh make_mesh_3 does not seem to always output one. Some inputs
seem to always result in a non-manifold mesh while others may result in a
non-manifold mesh occasionally without any change in inputs. I get the same
behavior regardless of whether I use mesh optimizations or disable them. Am
I doing something incorrectly?
Kind regards,
Kim
- [cgal-discuss] make_mesh_3 with manifold() specified outputing non-manifold mesh, Kim, 10/05/2020
- Re: [cgal-discuss] make_mesh_3 with manifold() specified outputing non-manifold mesh, Sebastien Loriot (GeometryFactory), 10/05/2020
