- To:
- Subject: Re: [cgal-discuss] Visualize non-2-manifold object
- Date: Thu, 8 Oct 2020 06:13:58 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi Guillaume,
Thank you for the solution for drawing the non-2-manifold objects.
Now this question crossed my mind that whether I would be able to do some
analyses on this merged file as one single object. Because at the end of the
day my next objective is to apply some rules such as checking the geometry
closure, self-intersection, planarity, etc on this non-2-manifold object.
Let me first try out your solution.
Best regards,
Ali
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 10/06/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Guillaume Damiand, 10/08/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 10/08/2020
