cgal-discuss - [cgal-discuss] Fastest way of running hundreds of booleans
  • To:
  • Subject: [cgal-discuss] Fastest way of running hundreds of booleans
  • Date: Mon, 2 Nov 2020 06:09:17 -0600 (CST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hello,
I'm currently cloning a mesh multiple times, and moving those clones in such
a way it ends up looking like they form a trail. I end up having something
between 200 and 300 clones of the meshes, which I will have to minus another
model from. Here I have three options: I can add the hundreds of clones
together and then minus the model from it, or I can straight up minus the
model from every single of those clones.
Both of my options are crazy slow - taking over 20 minutes to process. I
need the total time to be around the 1 minute mark.
Is there a way I can run booleans in parallel for the same set of meshes? Or
run some sort of combined boolean?
