cgal-discuss - Re: [cgal-discuss] Understanding Exact Computation in CGAL
  • To:
  • Subject: Re: [cgal-discuss] Understanding Exact Computation in CGAL
  • Date: Thu, 19 Nov 2020 10:58:23 +0100
Hi Himanshu,
On this particular subject, here is another « mooc » I made, which you may
find of interest :
https://www.youtube.com/watch?v=7cz7RNYoWow
Regards,
Sylvain
> Le 19 nov. 2020 à 10:06, Sebastien Loriot (GeometryFactory)
> ( via cgal-discuss Mailing List)
> <> a écrit :
> CGAL relies on an multiprecision number type.
> They are several alternative but the most used is the third party GMP.
> Then, since exact arithmetic is costly, they are several filters applied
> to avoid relying on this multiprecision number type (static filters,
> interval arithmetic, ...).
> You can watch the google tech talk starting from here:
> https://youtu.be/3DLfkWWw_Tg?t=2310
> to get more details.
> Best,
> Sebastien.
> On 11/19/20 2:48 AM, Himanshu Sharma ( via
> cgal-discuss Mailing List) wrote:
>> Hi Team,
>> I am trying to understand how CGAL goes about doing exact computation. You
>> have a page https://www.cgal.org/exact.html where you explain it a bit. I
>> need some clarification.
>> Quoting from the page:
>> In CGAL, we write the high-level algorithms in terms of a well-chosen set
>> of basic questions (where is a point with respect to a line?) and basic
>> objects (like a circle through three points). Doing this in the right way
>> is not always easy, but once it is done, we have outsourced all the
>> numerical issues, and we only have to make sure that the part of CGAL
>> concerned with the basics returns correct results. Given this, the
>> algorithms on top of it just work. Not in most cases, but always!
>> Can you tell me that how do you go about computing answers to set of
>> 'basic questions' ? Are you using a third party library for it or you
>> implement that part yourself ? If you do it yourself, can you guide me to
>> where I can find it in the source code.
>> Regards,
>> Himanshu
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://sympa.inria.fr/sympa/info/cgal-discuss
