Re: [cgal-discuss] Delaunay_triangulation when loaded from a file has "invalid" set
- To:
- Subject: Re: [cgal-discuss] Delaunay_triangulation when loaded from a file has "invalid" set
- Date: Thu, 26 Nov 2020 19:36:10 +0100 (CET)
On Thu, 26 Nov 2020, Renaud GILLON wrote:
Using the Delaunay_triangulation class with Epick_d kernel, we noticed that
after streaming the triangulation to a (text) file, closing the file, the
loading that file back into a new Delaunay_triangulatin object, the
"invalid" property is set to "true".
When trying to call the locate() function on the triangulation initialized
from the file, we get "trouble" (error messages). However if we make a copy
to a third triangulation object using a copy constructor, then the new
triangulation does not have "invalid" set and it works properly.
Is this a known issue ? Or should I report it as a bug with more detail ?
Opening an issue on github with a simple reproducer would be nice, thanks. I don't know what "invalid" property you are talking about (grep doesn't find the string "invalid" in this module).
Marc Glisse
- [cgal-discuss] Delaunay_triangulation when loaded from a file has "invalid" set, Renaud GILLON, 11/26/2020
- Re: [cgal-discuss] Delaunay_triangulation when loaded from a file has "invalid" set, Marc Glisse, 11/26/2020
- Re: [cgal-discuss] Delaunay_triangulation when loaded from a file has "invalid" set, Renaud GILLON, 11/26/2020
