- To:
- Subject: [cgal-discuss] Problem constructing sphere polygon
- Date: Mon, 7 Dec 2020 23:22:59 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi, I'm new to CGAL. I'm currently working on a project involving sphere polygons, including constructing sphere polygons from vertices coordinates, computing the areas of the polygons and compute intersections of two polygons. I found "2D Boolean Operations on Nef Polygons Embedded on the Sphere" has all the features. However I encountered a problem when constructing sphere polygons from a given coordinate list. Basically, the constructed Nef_polyhedron either has incorrect vertices numbers, or the coordinates don't match the input.
I've posted the detailed question on stackoverflow: https://stackoverflow.com/questions/65165733/cgal-construct-sphere-polyhedron. I have tried my best to make the code correct, but did not make it. Please feel free to give me some insights into the problem. Thank you.
Best regards,
Yang
- [cgal-discuss] Problem constructing sphere polygon, Yang Guo, 12/08/2020
