cgal-discuss - Re:[cgal-discuss]
Re:[cgal-discuss]
  • To:
  • Subject: Re:[cgal-discuss]
  • Date: Mon, 21 Dec 2020 08:49:11 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
You can have a look at https://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__predicates__grp.html#ga2ee87a0a4368a21654ee2817b93c85e4
and
https://doc.cgal.org/latest/Polygon_mesh_processing/classCGAL_1_1Side__of__triangle__mesh.html.
The first will tell you if 2 polyhedra intersect, and the second will tell you if one polyhedra is inside another.
Le sam. 19 déc. 2020 à 09:42, gakkiloving <> a écrit :
Dear developers and users,
I am a newbie of CGAL, now  I want to use the CGAL library to judge the positional relationship of some regular 3D polyhedras (similar to cubes and cuboids), such as judging whether two polyhedra intersect (or whether there is a "collision" between two geometric bodies), therefore, I would like to know which package in the CGAL library should I understand that enables me to detect collisions of 3D polyhedrons.
Thanks for your help.
签名由 网易邮箱大师 定制
  • [cgal-discuss], gakkiloving, 12/19/2020
    • Re:[cgal-discuss], Maxime Gimeno, 12/21/2020
