Re: [cgal-discuss] how the isovalue impact the vertices and facets of surface mesh
- To:
- Subject: Re: [cgal-discuss] how the isovalue impact the vertices and facets of surface mesh
- Date: Mon, 4 Jan 2021 20:52:55 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
You may use MITK to create iso-surface from volumetric images e.g. CT-scans.
Thanks
Sukhraj
On Sat, Dec 26, 2020, 8:07 AM ianben <> wrote:
I am trying to generate the surface mesh of a 3D binary segmented volumetric
label(the voxel value is 0 and 1) using the code in
Surface_mesher/mesh_a_3d_gray_image.cpp
<https://doc.cgal.org/latest/Surface_mesher/Surface_mesher_2mesh_a_3d_gray_image_8cpp-example.html>
. When I tried different isovalues ranging from 0.1-0.9, I get different
surface meshes with different vertices and facets.
It seems that the the isovalues was used to get the signs of f(p)-isovalue,
but what is the function f and how the isovalue can impact the meshing
result?
Thank you.
- Re: [cgal-discuss] how the isovalue impact the vertices and facets of surface mesh, Sebastien Loriot, 01/04/2021
- <Possible follow-up(s)>
- Re: [cgal-discuss] how the isovalue impact the vertices and facets of surface mesh, Sukhraj Singh, 01/04/2021
