- To:
- Subject: Re: [cgal-discuss] Delaunay triangulation in rectangular domain
- Date: Sun, 24 Jan 2021 17:52:11 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello,
sorry if it took me so much time to reply.
I have tried to compile the cgal examples in the repository but I have some errors and I can't understand why.
The error is described in the attached file, and it seems to be related to the absence of the library Periodic_2_Delaunay_triangulation_2_generic.h, which is not in my computer even if cgal is installed. I find a similar error for the three-dimensional example.
CGAL has only Periodic_2_Delaunay_triangulation_2.h. However, if I compile it with this one, I get a lot of other errors.
Sorry if the mistake might be silly but I am a newbie in cpp and cgal.
Thanks a lot for your help and your time.
Il giorno lun 14 dic 2020 alle ore 17:27 Mael Rouxel-Labbé <> ha scritto:
Hello,
There is a feature under development that adds support for periodic
triangulations of such domain. You can find a stable (but unfinished)
version here :
https://github.com/MaelRL/cgal/tree/Generic_Periodic_Triangulations
<https://github.com/MaelRL/cgal/tree/Generic_Periodic_Triangulations>.
In this new version of the package, the base domain that is periodically
duplicated is a Voronoi face, described by a lattice basis of vectors; 3
vectors in your 2D case. See the associated paper :
https://drops.dagstuhl.de/opus/volltexte/2020/12941/pdf/LIPIcs-ESA-2020-75.pdf
<https://drops.dagstuhl.de/opus/volltexte/2020/12941/pdf/LIPIcs-ESA-2020-75.pdf>
for more details, explanations on how it works, etc.
The code is developed in the existing package
"Periodic_2_triangulation_2" (and "Periodic_3_triangulation_3" for the
3D version). You should base your code on this example :
https://github.com/MaelRL/cgal/blob/Generic_Periodic_Triangulations/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp
<https://github.com/MaelRL/cgal/blob/Generic_Periodic_Triangulations/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp>.
Let me know if you encounter any issue or have any question.
Best,
Mael
On 14/12/2020 09:41, Giammi ( via cgal-discuss
Mailing List) wrote:
> Dear all,
> I am a newbie of cpp and cgal.
> I would like to write a code in which particles move in a 2D rectangular
> domain ( with periodic boundary conditions) and then interact with their
> neighbors in a Delaunay triangulation.
> Currently, I am working with a code that has the precondition that the
> domain must be a square and I can't find anything in the documentation that
> could help me in changing the size of the domain.
> Therefore, I would like to ask you if there is any package that lets me work
> on a rectangular domain?
> Thanks a lot for your help.
> Best,
> Gianmarco
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
https://github.com/MaelRL/cgal/blob/Generic_Periodic_Triangulations/README.md
that is to execute the following command lines
mkdir /path/to/cgal
git clone :MaelRL/cgal.git /path/to/cgal // or download the
code directly from
https://github.com/MaelRL/cgal/archive/Generic_Periodic_Triangulations.zip
cd
/path/to/cgal/Periodic_3_triangulation_3/examples/Periodic_3_triangulation_3
mkdir -p build/debug
cd build/debug
cmake -DCMAKE_BUILD_TYPE=Debug -DCGAL_DIR=/path/to/cgal ../..
make generic_p3t3
Before executing the last line, I create the example file generic_p3t3.cpp in
the directory
cd
and then I use make generic_p3t3
It gives me the following
gianmarcospera@Giammi:~/cgal/Periodic_3_triangulation_3/examples/Periodic_3_triangulation_3/build/debug$
make generic_p3t3
Scanning dependencies of target generic_p3t3
[ 50%] Building CXX object CMakeFiles/generic_p3t3.dir/generic_p3t3.cpp.o
/home/gianmarcospera/cgal/Periodic_3_triangulation_3/examples/Periodic_3_triangulation_3/generic_p3t3.cpp:5:10:
fatal error:
CGAL/Generic_P3T3/Periodic_3_Delaunay_triangulation_3_generic.h: No such file
or directory
5 | #include
<CGAL/Generic_P3T3/Periodic_3_Delaunay_triangulation_3_generic.h>
compilation terminated.
make[3]: *** [CMakeFiles/generic_p3t3.dir/build.make:63:
CMakeFiles/generic_p3t3.dir/generic_p3t3.cpp.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:372: CMakeFiles/generic_p3t3.dir/all]
Error 2
make[1]: *** [CMakeFiles/Makefile2:379: CMakeFiles/generic_p3t3.dir/rule]
Error 2
make: *** [Makefile:248: generic_p3t3] Error 2
I don't know how to fix it
If I try with the 2dExample ( moving to the corresponding directory ), I have
this error message
gianmarcospera@Giammi:~/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/build/debug$
make generic_p2t2
[ 50%] Building CXX object CMakeFiles/generic_p2t2.dir/generic_p2t2.cpp.o
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:3:10:
fatal error:
CGAL/Generic_P2T2/Periodic_2_Delaunay_triangulation_2_generic.h: No such file
or directory
3 | #include
<CGAL/Generic_P2T2/Periodic_2_Delaunay_triangulation_2_generic.h>
make[3]: *** [CMakeFiles/generic_p2t2.dir/build.make:63:
CMakeFiles/generic_p2t2.dir/generic_p2t2.cpp.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:426: CMakeFiles/generic_p2t2.dir/all]
Error 2
make[1]: *** [CMakeFiles/Makefile2:433: CMakeFiles/generic_p2t2.dir/rule]
Error 2
make: *** [Makefile:274: generic_p2t2] Error 2
The cgal library is already install in my laptop.
The same error occurs if I try to compile the example from terminal without
make.
The error if I use Periodic_2_Delaunay_triangulation_2.h
home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:16:15:
error: ‘Lattice_2’ in namespace ‘CGAL’ does not name a template type
16 | typedef CGAL::Lattice_2<K>
Lattice;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:17:15:
error: ‘Periodic_2_triangulations_2’ in namespace ‘CGAL’ does not name a
type; did you mean ‘Periodic_2_triangulation_2’?
17 | typedef
CGAL::Periodic_2_triangulations_2::internal::Lattice_construct_point_2<K>
CP2;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:18:15:
error: ‘Periodic_2_Delaunay_triangulation_traits_base_2’ in namespace ‘CGAL’
does not name a template type; did you mean
‘Periodic_2_Delaunay_triangulation_2’?
18 | typedef CGAL::Periodic_2_Delaunay_triangulation_traits_base_2<K,
Offset, Lattice, CP2> GT;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:20:15:
error: ‘Periodic_2_triangulation_vertex_base_2_generic’ in namespace ‘CGAL’
‘Periodic_2_triangulation_vertex_base_2’?
20 | typedef CGAL::Periodic_2_triangulation_vertex_base_2_generic<GT>
Vb;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:21:15:
error: ‘Triangulation_face_base_with_info_2’ in namespace ‘CGAL’ does not
name a template type; did you mean ‘Triangulation_face_base_2’?
21 | typedef CGAL::Triangulation_face_base_with_info_2<std::pair<bool,
CGAL::Color>, GT> Fbb;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:22:15:
error: ‘Periodic_2_triangulation_face_base_2_generic’ in namespace ‘CGAL’
‘Periodic_2_triangulation_face_base_2’?
22 | typedef CGAL::Periodic_2_triangulation_face_base_2_generic<GT, Fbb>
Fb;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:23:46:
error: ‘Vb’ was not declared in this scope
23 | typedef CGAL::Triangulation_data_structure_2<Vb, Fb>
Tds;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:23:50:
error: ‘Fb’ was not declared in this scope; did you mean ‘FT’?
Tds;
| FT
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:23:52:
error: template argument 1 is invalid
Tds;
error: template argument 2 is invalid
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:24:15:
error: ‘Periodic_2_Delaunay_triangulation_2_generic’ in namespace ‘CGAL’
24 | typedef CGAL::Periodic_2_Delaunay_triangulation_2_generic<GT, Tds>
GPDT;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:26:9:
error: ‘GPDT’ does not name a type
26 | typedef GPDT::Point
Point;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:28:9:
28 | typedef GPDT::Vertex_handle
Vertex_handle;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:29:9:
29 | typedef GPDT::Face_handle
Face_handle;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:31:37:
error: ‘Point’ was not declared in this scope
31 | typedef CGAL::Creator_uniform_2<FT, Point>
Creator;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:31:42:
Creator;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:32:41:
32 | typedef CGAL::Random_points_in_square_2<Point, Creator>
Point_generator;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:32:55:
Point_generator;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:33:41:
33 | typedef CGAL::Random_points_on_circle_2<Point, Creator>
Point_on_circle_generator;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:33:55:
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:35:1:
error: ‘Lattice’ does not name a type
35 | Lattice generate_random_lattice(CGAL::Random& rnd)
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:56:13:
56 | std::vector<Point> generate_random_points_in_lattice(const
std::size_t n, CGAL::Random& rnd, const Lattice& l)
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:56:18:
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:56:100:
56 | r<Point> generate_random_points_in_lattice(const std::size_t n,
In function ‘int generate_random_points_in_lattice(std::size_t,
CGAL::Random&, const int&)’:
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:58:15:
58 | std::vector<Point> pts;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:58:20:
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:59:7:
error: request for member ‘reserve’ in ‘pts’, which is of non-class type
‘int’
59 | pts.reserve(n);
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:65:9:
error: request for member ‘push_back’ in ‘pts’, which is of non-class type
‘int’
65 | pts.push_back(CGAL::ORIGIN + l0 * l.basis()[0] + l1 *
l.basis()[1]);
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:65:41:
error: request for member ‘basis’ in ‘l’, which is of non-class type ‘const
int’
l.basis()[1]);
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:65:61:
int’
l.basis()[1]);
In function ‘int main(int, char**)’:
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:79:9:
79 | const Lattice l = generate_random_lattice(rnd);
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:80:21:
80 | const std::vector<Point> pts =
generate_random_points_in_lattice(number_of_points, rnd, l);
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:80:26:
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:80:91:
error: ‘l’ was not declared in this scope
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:87:3:
error: ‘GPDT’ was not declared in this scope
87 | GPDT Tr(l);
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:88:13:
error: ‘Point’ does not name a type
88 | for(const Point& pt : pts)
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:89:19:
error: expected ‘;’ before ‘std’
89 | Tr.insert(pt);
90 |
91 | std::cout << "Done!" << std::endl;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:92:42:
error: ‘Tr’ was not declared in this scope
92 | std::cout << "Number of vertices: " << Tr.number_of_vertices() <<
std::endl;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:92:78:
error: expected ‘)’ before ‘;’ token
std::endl;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:88:6:
note: to match this ‘(’
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:93:39:
93 | std::cout << "Number of faces: " << Tr.number_of_faces() <<
std::endl;
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:101:22:
error: variable ‘std::ofstream out’ has initializer but incomplete type
101 | std::ofstream out("final.off");
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:102:11:
error: ‘write_PD2T2_to_OFF’ is not a member of ‘CGAL’
102 | CGAL::write_PD2T2_to_OFF(out, Tr.p2dt2);
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:106:22:
106 | std::ofstream out("final.off");
/home/gianmarcospera/cgal/Periodic_2_triangulation_2/examples/Periodic_2_triangulation_2/generic_p2t2.cpp:107:11:
error: ‘write_DT2_to_OFF’ is not a member of ‘CGAL’
107 | CGAL::write_DT2_to_OFF(out, Tr.dt2);
Error 2
Error 2
- Re: [cgal-discuss] Delaunay triangulation in rectangular domain, Gianmarco Spera, 01/24/2021
- Re: [cgal-discuss] Delaunay triangulation in rectangular domain, Mael Rouxel-Labbé, 01/25/2021
- Re: [cgal-discuss] Delaunay triangulation in rectangular domain, Gianmarco Spera, 01/25/2021
