- To:
- Subject: Re: [cgal-discuss] Problem With CMake for CGGAL 5.2
- Date: Mon, 25 Jan 2021 10:19:37 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
On Sunday, January 24, 2021 12:59:39 AM CET Jeb Gaither wrote:
> Hi
> I am not sure what is wrong. I am trying to update to CGAL 5.2
> I have successfully downloaded 5.2, Boost 1_17_0, CMake 3.19.3.
> I have tried to Configure Demos, Examples, etc with similar results to the
> attached error log.
Dear Jeb, the CMake error is the following:
> CMake Error at CMakeLists.txt:21 (find_package):
> By not providing "FindCGAL.cmake" in CMAKE_MODULE_PATH this project has
> asked CMake to find a package configuration file provided by "CGAL", but
> CMake did not find one.
> Could not find a package configuration file provided by "CGAL" with any of
> the following names:
> CGALConfig.cmake
> cgal-config.cmake
> Add the installation prefix of "CGAL" to CMAKE_PREFIX_PATH or set
> "CGAL_DIR" to a directory containing one of the above files. If "CGAL"
> provides a separate development package or SDK, be sure it has been
> installed.
That says CMake was not able to find the install path of CGAL-5.2 by itself.
Let's suppose you have copied CGAL-5.2 into
C:/Users/Jeb Gaither/Documents/Art/CGAL-5.2/
then, in the CMake GUI, you must set the CMake `CGAL_DIR` cache variable to
the same path:
You can also set `CGAL_DIR` as an environment variable.
Laurent Rineau, PhD
- [cgal-discuss] Problem With CMake for CGGAL 5.2, Jeb Gaither, 01/24/2021
- Re: [cgal-discuss] Problem With CMake for CGGAL 5.2, Sebastien Loriot, 01/25/2021
- Re: [cgal-discuss] Problem With CMake for CGGAL 5.2, Laurent Rineau (CGAL/GeometryFactory), 01/25/2021
- RE: [cgal-discuss] Problem With CMake for CGGAL 5.2, Jeb Gaither, 01/25/2021
- Re: [cgal-discuss] Problem With CMake for CGGAL 5.2, Maxime Gimeno, 01/26/2021
