cgal-discuss - Re: [cgal-discuss] Help to read a mesh written with output_to_medit.
  • To:
  • Subject: Re: [cgal-discuss] Help to read a mesh written with output_to_medit.
  • Date: Wed, 27 Jan 2021 09:01:44 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
 medit is the default format read by the `operator>>` of the c3t3.
Le mer. 27 janv. 2021 à 00:39, Tony Apicella <> a écrit :
Hello,
I have written a mesh_3 to a file using output_to_medit, as in the mesh_3D_gray_image example.  Is there some way to read it back?
I tried CGAL::read_MEDIT but could not link, with error that CGAL::build_triangulation_from_file is an unresolved symbol.
Thank you.
