cgal-discuss - Re: [cgal-discuss] Using CGAL with qt5
  • To:
  • Subject: Re: [cgal-discuss] Using CGAL with qt5
  • Date: Sat, 30 Jan 2021 23:39:02 -0600 (CST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
For some reason the latest documentation doesn't show the 'CMakeLists.txt'
file for this "Minimal Example Using Qt5" - you can switch to some other
version, then you'll see it.
However, this example source file together with the 'CMakeLists.txt' can be
found in the '<CGAL root dir>/examples/Surface_mesh' directory, so you can
compile it as usual:
mkdir build && cd build
cmake -DCGAL_DIR=<directory with cmake finders> ..
make draw_surface_mesh
