- To:
- Subject: Re: [cgal-discuss] Using CGAL with qt5
- Date: Wed, 3 Feb 2021 09:52:34 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On Wed, 3 Feb 2021 at 08:26, Sebastien Loriot <> wrote:
You should not give include paths by hand but use the cmake config file
generated by your QT installation.
See https://doc.cgal.org/latest/Manual/configurationvariables.html#title9
Qt5_DIR can be a cmake variable (cmake -DQt5_DIR=...) or an environment
variable.
CMake Warning:
Manually-specified variables were not used by the project:
Qt5_DIR
The previous suggestion (i.e. using CMakeLists.txt from the examples) works as well as the manual configuration I posted in the first place - that is, I end up with:
Qt5_DIR
/usr/local/include/CGAL/Qt/image_interface.h:21:10: fatal error:
'ui_ImageInterface.h' file not found
#include "ui_ImageInterface.h"
Sebastien.
On 1/30/21 5:30 PM, Ben Laurie wrote:
> I'm trying to compile the basic example
> (https://doc.cgal.org/latest/Manual/devman_create_and_use_a_cmakelist.html#subcmake
> <https://doc.cgal.org/latest/Manual/devman_create_and_use_a_cmakelist.html#subcmake>)
> and I have to pass lots of arguments to CMake to include the qt5 files
> ... like this:
> cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-Wall -Werror
> -I/usr/local/include/qt5 -I/usr/local/include/qt5/QtWidgets
> -I/usr/local/include/qt5/QtGui -I/usr/local/include/qt5/QtXml
> -I/usr/local/include/qt5/QtCore -I/usr/local/include/qt5/QtOpenGL -fPIC" .
> Is this expected? Anyway, after tracking all these down, I end up with
> the error:
> and there's no such file on my machine. Any clue what I'm doing wrong?
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- Re: [cgal-discuss] Using CGAL with qt5, Sebastien Loriot, 02/03/2021
- Re: [cgal-discuss] Using CGAL with qt5, Ben Laurie, 02/03/2021
