cgal-discuss - [cgal-discuss] How to use custom lib along with CGAL (makefile doubt)
  • To:
  • Subject: [cgal-discuss] How to use custom lib along with CGAL (makefile doubt)
  • Date: Sat, 6 Feb 2021 01:18:57 -0600 (CST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi,
I want to use cgal library(Apollonius Diagram) along with my code. Where do
i find CGAL make file inorder to merge it with my makefile.
My makefile looks like this.
CXX = g++
OUT = run
CPPFLAGS = -O3 -std=c++14
#LDFLAG = -lstdc++ -std=c++0x
#DEPRECATE = -Wno-deprecated
#DEBUGFLAG = -g
OBJ = main.o spatial_price.o
$(OUT): $(OBJ)
$(CXX) $(CPPFLAGS) $(OBJ) -o $@ -L. -ltao
#run the following command afterwards
# export LD_LIBRARY_PATH=.:$LD_LIBRARY_PATH
main.o: main.cpp
$(CXX) -c $(CPPFLAGS) $< -o $@
spatial_price.o: spatial_price.cpp
clean:
rm *.o *~ $(OUT)
Running cmake . and then make helps me build and run the cgal programs. But
how do i incorporate my custom made library in this.
Thanks,
VSav
