cgal-discuss - Re: [cgal-discuss] need help with vcpkg build on Windows- .vtu file - useful to save as ASCII...
  • To:
  • Cc: "Tapp, Austin" <>
  • Subject: Re: [cgal-discuss] need help with vcpkg build on Windows- .vtu file - useful to save as ASCII...
  • Date: Mon, 8 Mar 2021 08:55:22 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:/ZunEhIS+jXMHt/WYNmcpTZWNBhigK39O0sv0rFitYgXI/z+rarrMEGX3/hxlliBBdydt6sVzbOP6uu5ATdIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfLd/IA+roQnMq8UajpZuJro/xxDUvnZGZuNayH9yK1mOhRj8/MCw/JBi8yRUpf0s8tNLXLv5caolU7FWFSwqPG8p6sLlsxnDVhaP6WAHUmoKiBpIAhPK4w/8U5zsryb1rOt92C2dPc3rUbA5XCmp4ql3RBP0jioMKiU0+3/LhMNukK1boQqhpx1hzI7SfIGVL+d1cqfEcd8HWWZNQsNdWipcCY2+coQPFfIMMulWr4b/p1UAoxiwCxSyCuzzxTFFnWP23bQg3ug9DQ3KwA4tEtQTu3rUttX1M6ISXPiywqbSwjTDbvZW1ing44bJcxAhpO+DXbR3ccHMzkQvEhnKj1qRqYzgITyZzOsNs2me7+V+U+KvjHUqqw50oje1x8csjpPFiZ4SylDB7Ch0xps+KtKkRkBhe9GkDIdQuD+AN4twWs4vQm9mtDo7x7ACt5O3YicHxZU5yxPed/GKcIqF7BzjWeuRPzp0mnFodb27ihuz8kWtyvPxWtSq3VpWsCZJj9rBu3YQ3BLd7ciHT+Fy/kan2TuX0ADT9/1EIUQzlarcKJ4t2KI/lp0WsUjbHy/2nl/2jK6MeUk+9Oio8eLqaajlqJ+EL4J4lB3yP6A0lsG8Aek0KBYCU3WH9eim27Du+Uv0S6hQgPIsiKnWqpXaKNwbpqGnBw9V1Z4u6xOlADen1NQUhH4HLE5YdB6egYjkNFXDLOr3Dfe4hFSsnzNryO7cMrL9BZXNK2DPkLbnfblj905R0BQ/wcxb6p5OCbwMIOj/VlHsuNDEFBM0PAi5z/7iCNpn14MeXWyPArWeMKPXqVKI4/ggIuaNZI8QpjnxMfcl5//rjXAnn18derKk3ZQSaH+iH/RmJ1+VbmbrgtcECWsKpBYxTPT2iF2eVj5ef2q9X60m6TE/EY6pEIbDRpuxj7ycxye7BYZbZntGC1CJCXfnbZ+IW/YKaCKII89uiCYIVba7S9xp6Be1qQWvy6Z7NvGGvWoevJe6jZ5u7uPekRA09icyF96az2yGU2BzmCUPWiMy26d850d6zxDUzLJ81vxECcRIqqhgH10UeMTy1P1/E9m0HAPHZNaADli8D4+IGiA0Vtt8mfEPZUh6Vo+MhR/K22+mAqQeiqeQSpUx6vHQ1mT4cp4hhintjPBs0HIjS9ZDOHG6i+Mjrw/fGsiPnkmE2vmBe6oQ0SCS/WrZlzuD4B5UCF8qX/+dDXxPaxLc89r3t02PEJTyWb4pYlVMmZfbI/EWYI3g3V5MH6mzNITUbjjrwTi+XlvX7evBM6GyNjo2gn6CVRBbzlpIpibda1RjW3z77j31MTptE1XwZQ6z2tVBhmuxYX0vxVqGP0Bw9YWU+BkUoNfAVNcR960hlA4gjx5WJXe/2NPoUd6dghhAfYF3Q/kB4XYZ9GGAtwVCIZ2EBIJSuHU/LSFx5w61+1goIdwYyZBkpXYynxF+IL6RhU1nRS+35YLbOJ3Oemjp+gy3MrP852/12sjboI1U1Oonkhi5kl6TPVE72l4qifN+3l7RvbmEBQ8KAoj8SUst6RV28umJXy8m+omB1WFwKbLm9XjZytcxDa0kzAyhdpFRKuSfBQrqGoobAcapb+clklzsYhMfN/1J7/0JOdi7fceLyLL+PPp8hCn0yiNB6YUkiwSX/iRxTu/O3I1D2+ufwgaMSzb7ihGmr9zznodHIzoVGy3o1DLgUY5NerVpMN0iRD2AbpeZ3cR7n5erHX9e7l+qQV0clZWHYguXd1WwhyNR00oQ7CaJkiSxy3l4kiois7GEkiXL27fufQYObzYXCTZJ1Q6hfqOxhs0WUVS0YkV1zByp+AC8yqRG6ftUIWffTEkXdiWsdTBvDvS87uvYbZQXuJ94vHxdDuqyMF7XFZWh8xEUg33uTzIHzWpnfWGj6p7zxEIqhDKXISwp9iXXIowv7k+Su/eECKF6gGFZGXEn1GOMXQjnYYX0oI7O2sjoj+a9UWW+UNAMWhXU45uKmxmg7zZmURCuvc+SmNrmNCNmzgv5/sZPeQzJiD3eW6jp0KWEa+Z6W1tJBXvXyeBGG6Ags4hphJgvxnk+rbelw1Emz0L1aZgA9e+hRyNVHWZFytvNsxPp0VFqe2yv9Z7Wbme2wOt4N9ihZH8Ogz8X0v5hArnZtpYfoTVqmxfig13rSuNktxxQk9EF5VtX2M1HsQ81nT+QGb0IA0RUaHS/qhKT8tqCobVLMWazbaCrhg05hsGkFLjEowdGWX+/dI1lBj519sw4MVTC1zr45YjgPdXRdtkOrQbHrxCVhOdcLNc9l+EBmDF8EWP7p3wsjeAh3jJ02pTvmYGXKmBgtI24BxNeMXWhYsoD+zTgy6lfm8uQ2KigG5xgHnMAW56+HqHgKy4bqfmyb1XGKzY7sHrOXOOHRVbOuncjlGrGFtWQD1/SIXAYydt4QxzEfR5QhQkVWHMxmZtrT1n3lvykS19w43Uq3nC9qhZIzbg1ZRz2U2OaoxvxLzloGd6QKx1Z6gwE7EDQY5THsrBDWhpA95jklzSjb3SBbl0RX24MU02AQVvkO+v26A==
Hi,
Sorry for your trouble with using vcpkg. I just had a look and things
have changed since the last time I did. I'll put order to the
dependencies soon.
Le lun. 8 mars 2021 à 04:20, Audette, Michel A. <> a écrit :
> Hi again,
> looks like Paraview needs me to save .vtu files as ASCII to be able to
> parse them. I tweaked the mesh_polyhedral_domain_with_features.cpp example
> with the ASCII flag as parameter.
> CGAL::output_to_vtu(file, c3t3, CGAL::IO::ASCII);
> Now able to see it on Paraview. I will be playing around with various
> tetrahedralization parameters from now on.
> Sorry for the Internet traffic.
> Michel
> Michel Audette, Ph.D.
> Associate Professor, Department of Computational Modeling and Simulation
> Engineering,
> Graduate Program Director, Biomedical Engineering Institute,
> Old Dominion University,
> Norfolk, VA.
> ; cellphone: 757-470-1279 .
> ________________________________
> From: <> on
> behalf of Audette, Michel A. <>
> Sent: Sunday, March 7, 2021 8:53 PM
> To: <>
> Cc: Tapp, Austin <>
> Subject: Re: [cgal-discuss] need help with vcpkg build on Windows- problem
> with .vtu file produced by
> Hi Marc,
> after all, I installed boost myself, separate from CGAL, and the problem
> went away. CGAL has its own internal boost installation, so I'm wondering
> why it does not include an up-to-date, inclusive set of software classes
> that has callable_traits as part of the complete imbedded boost set. If I
> cannot trust that CGAL-embedded boost installation as complete, as part of
> the vcpkg cgal installation, then the online doc should indicate that this
> instruction is incomplete. After all, the doc says:
> You are now ready to install CGAL:
> C:\dev\vcpkg> ./vcpkg.exe install cgal
> This will take several minutes as it downloads MPIR (a fork of GMP), MPFR,
> all boost header files, and it will compile MPIR and MPFR, as well as
> several boost libraries. Afterwards, you will find the include files,
> libraries, and dlls in the subdirectory C:\dev\vcpkg\installed\x64-windows.
> Anyhow, if I install boost separately (in the same x64-windows directory,
> i.e. : vcpkg.exe install boost:x64-windows), I'm now able to compile and
> run the Mesh_3 examples... I am trying to run variational tet meshing with
> an imposed polyhedral surface mesh, to produce a resolution-controlled tet
> mesh that is faithful to the discrete surface (I view this Rineau/Alliez
> variational algorithm as the best tet meshing algorithm available in
> public, which is why I go to this trouble).
> However, starting with baby steps, such as the basic examples like
> mesh_polyhedral_domain_with_features.cpp. Just wondering about the out.vtu
> file produced by mesh_polyhedral_domain_with_features.cpp. When I try to
> visualize it on Paraview, the latter complains:
> ERROR: In
> C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\XML\vtkXMLUnstructuredDataReader.cxx,
> line 686
> vtkXMLUnstructuredGridReader (000001AF6F9E3D90): Cannot read cell
> connectivity from Cells in piece 0 because the "offsets" array is not
> monotonically increasing or starts with a value other than 0.
> Any idea why? Can you suggest something else to read and visualize vtu
> files?
> Thanks for your support. Warm wishes,
> Michel
> Engineering,
> Norfolk, VA.
> From: <> on
> behalf of Marc Glisse <>
> Sent: Sunday, March 7, 2021 5:18 PM
> To: <>
> Cc: Tapp, Austin <>
> with boost/callable_traits not built
> On Sun, 7 Mar 2021, Audette, Michel A. wrote:
> > in trying to build Mesh_3 examples, I'm finding that the
> > boost/callable_traits directory is not set up properly with vcpkg. I
> > cannot find it anywhere, so the compiler complains of not finding
> > is_invocable.hpp.
> Sorry for the obvious question, but did you install the
> boost-callable-traits vcpkg package?
> Marc Glisse
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsympa.inria.fr%2Fsympa%2Finfo%2Fcgal-discuss&amp;data=04%7C01%7Cmaudette%40odu.edu%7Cffdef7ae229e47d092f208d8e1b6ff9f%7C48bf86e811a24b8a8cb368d8be2227f3%7C0%7C0%7C637507523383645532%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&amp;sdata=vNZtGPzCjHq8isntp1uBUVCbv%2B3TvwQ%2F7RCsqAC%2BCeM%3D&amp;reserved=0
> https://sympa.inria.fr/sympa/info/cgal-discuss
