- To:
- Subject: Re: [cgal-discuss] how to understand CGAL's computational accuracy
- Date: Fri, 12 Mar 2021 13:54:19 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:O3T7tagKd7XwP65yvb5+oHvEGHBQX9x13DAbvn1ZSRFFG/GwvcaogfgdyFvQgDEeRHkvlbm7SdS9aFnb8oN45pRUAKyrWxPotHDtAIZp64bjxDOIIVyDysd206B8f69iTODhFFQSt7eB3CCUMfYFhOOG/qehmPvEwx5WJz1CRql8425Ce2CmO2JsQg0uP+tcKLO94Y59qyOkaTAraK2AdwI4dszig/GOq578ex4BAHccmXGzpBel8qTzHRTd/jp2aUIp/Z4Y/WLIkxP068yY2pnRqiP07GPd449bn9Hs0LJ4damxo/MYNyn2jUKQbJlhMofigBkOvOqt5Fw2+eO8wCsIAsIb0QKyQkiIuxf3nyHv3DEygkWSsGOwsD/MpYjcSCghA8RMwbhFegbUgnBNgPhMlIxM2Wydu957LzPl2B786d/BSg1wmiOPzEYKoKo8iXpQVIdbUrtNtMgk+l9PGptoJk3HwbFiK+VlAMHC6Ps+Sz2nU0w=
- Ironport-phdr: A9a23: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
If you use std::cout << std::setprecision(17) << p << " " << q << " " << r << "\n"; in both cases you will see that the input are different.
you will have:
0 0.29999999999999999 1 0.59999999999999998 2 0.90000000000000002
not collinear
0 0.30000000000000004 1 0.60000000000000009 2 0.89999999999999991
collinear
So the input are different, nothing specific to CGAL.
Best,
Sebastien.
On 3/12/21 1:45 PM, Aomandeyi ( via cgal-discuss Mailing List) wrote:
I still couldn't understand the official explanations,the two sets of data is
exactly the same ,
why the results is different? can someone talk about his own understanding?
the codes as follow
#include <iostream>
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <sstream>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef Kernel::Point_2 Point_2;
int main()
Point_2 p(0, 0.3), q(1, 0.6), r(2, 0.9);
std::cout << (CGAL::collinear(p, q, r) ? "collinear\n" : "not
collinear\n");
std::istringstream input("0 0.3 1 0.6 2 0.9");
input >> p >> q >> r;
collinear\n");
return 0;
- [cgal-discuss] how to understand CGAL's computational accuracy, Aomandeyi, 03/12/2021
- Re: [cgal-discuss] how to understand CGAL's computational accuracy, Sebastien Loriot, 03/12/2021
- Re: [cgal-discuss] how to understand CGAL's computational accuracy, Aomandeyi, 03/12/2021
- Re: [cgal-discuss] how to understand CGAL's computational accuracy, Marc Glisse, 03/12/2021
- Re: [cgal-discuss] how to understand CGAL's computational accuracy, Aomandeyi, 03/13/2021
