- To:
- Subject: Re: [cgal-discuss] Can't use Eigen matrices with CGAL::Gmpq
- Date: Tue, 23 Mar 2021 17:31:31 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-hdrordr: A9a23:o5cRXK1tZCgWbxsCHkTg4AqjBGUkLtp033Aq2lEZdDV+dMuEm8ey2MkB3RjvhzoLHF0mk9aMOK6PKEm9ybde544NMbC+GDT3oWfAFuBfxKbr3jGIIUfD38FH06MIScRDIfnRKXQ/ssrg+gm/FL8bruWv1Kyzn+/RwzNMYGhRAJ1I1AtyBgaFHkAefmAvObMCCJGe6sBbzgDMRV0raK2AaUU4Yw==
- Ironport-phdr: A9a23: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
"The class CORE::Expr provides exact computation over the subset of real
numbers that contains integers"
How does this class work? Does it preserve exact precision and then
sacrifices it when a square root is required?
Thanks for the proposed solution, by the way.
- [cgal-discuss] Can't use Eigen matrices with CGAL::Gmpq, aseverino, 03/23/2021
- Re: [cgal-discuss] Can't use Eigen matrices with CGAL::Gmpq, Marc Glisse, 03/23/2021
- Re: [cgal-discuss] Can't use Eigen matrices with CGAL::Gmpq, aseverino, 03/23/2021
