- To:
- Cc: Anthony Webber <>
- Subject: Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example
- Date: Tue, 20 Apr 2021 12:44:26 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:naVDOa7zvk7xGJM1QAPXwHDXdLJzesId70hD6mlaTxtJfsuE0/2/hfhz726WtB89elEF3eqBNq6JXG/G+fdOiuMsFJqrQQWOggqVBa5464+K+VHdMgj/7PMY6aB7b6NlAsbxBlQSt7ec3CCdM/INhOaK67qpg+C29RdQZCVncbtp4Qs8KivzKDwReCB8CZA0FIWR66N8zlKdUE8ad8GqQkQCNtKsm/TwiJnkbRQabiRL1CCyi1qTh4LSIlyz2BMGVjtOxqo5tVXC+jaJg5mLgrWVxhPQ3GfY7dB3tbLau79+Lf3JrsAULzn24zzYBrhcZw==
- Ironport-phdr: A9a23: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
What is the value for CGAL_DIR in cmake-gui ?
Le mar. 20 avr. 2021 à 11:57, Simon Giraudot <> a écrit :
Hello,
The Eigen directory looks correct.
Again, as Sébastien pointed in his first message, the error message suggests that the CGAL version you are using is different from the version of the example.
How did you install CGAL? What version is it? If you use examples from CGAL 5.2, you should install CGAL 5.2 in the first place.
Best,
-- Simon Giraudot, PhD R&D Engineer GeometryFactory - http://geometryfactory.com/Le 19/04/2021 à 16:26, Anthony Webber a écrit :
Still no go I'm afraid.
I have been using https://github.com/CGAL/cgal/releases/download/v5.2.1/CGAL-5.2.1-examples.tar.xz.
Tried changing every occurence of Eigen3 to Eigen in CMakeLists.txt, and deleting CMakeCache.txt, but still the same error.
On 19/04/2021 12:12, Maxime Gimeno ( via cgal-discuss Mailing List) wrote:
You should try to use the examples in https://github.com/CGAL/cgal/releases/download/v5.2.1/CGAL-5.2.1-examples.tar.xz then
Le lun. 19 avr. 2021 à 12:05, Anthony Webber <> a écrit :
That doesn't seem to work. :(. Same error.
I am using CGAL 5.2.1 and Eigen 3.4.99.
On 19/04/2021 10:23, Sebastien Loriot ( via
> Most probably, the example your are using does not match with the
> release of CGAL you are using.
> You can rename CGAL_Eigen3_support to CGAL_Eigen_support in the
> CMakeLists.txt and it should work.
> The change was introduced by this PR:
> https://github.com/CGAL/cgal/pull/5360
> only merged in the master branch targeting CGAL 5.3
> Best,
> Sebastien.
> On 4/19/21 11:18 AM, Anthony Webber wrote:
>> Please excuse my naivety.
>> I am attempting to build the Poisson_surface_reconstruction_3
>> example. Below is the cmake output. Could you tell me what I need to do?
>> cmake -DCMAKE_BUILD_TYPE=Release .
>> -- The C compiler identification is GNU 9.3.0
>> -- The CXX compiler identification is GNU 9.3.0
>> -- Check for working C compiler: /usr/bin/cc
>> -- Check for working C compiler: /usr/bin/cc -- works
>> -- Detecting C compiler ABI info
>> -- Detecting C compiler ABI info - done
>> -- Detecting C compile features
>> -- Detecting C compile features - done
>> -- Check for working CXX compiler: /usr/bin/c++
>> -- Check for working CXX compiler: /usr/bin/c++ -- works
>> -- Detecting CXX compiler ABI info
>> -- Detecting CXX compiler ABI info - done
>> -- Detecting CXX compile features
>> -- Detecting CXX compile features - done
>> -- Using header-only CGAL
>> -- Targetting Unix Makefiles
>> -- Using /usr/bin/c++ compiler.
>> -- Found GMP: /usr/local/lib/libgmp.so
>> -- Found MPFR: /usr/lib/x86_64-linux-gnu/libmpfr.so
>> -- Found Boost:
>> /usr/lib/x86_64-linux-gnu/cmake/Boost-1.71.0/BoostConfig.cmake (found
>> suitable version "1.71.0", minimum required is "1.48")
>> -- Boost include dirs: /usr/include
>> -- Boost libraries:
>> -- Using gcc version 4 or later. Adding -frounding-math
>> -- Found Eigen3: /usr/local/include/eigen3 (found suitable version
>> "3.4.99", minimum required is "3.1.0")
>> CMake Error at CMakeLists.txt:34 (include):
>> include could not find load file:
>> CGAL_Eigen3_support
>> -- NOTICE: The examples need Eigen 3.1 (or greater) will not be
>> compiled.
>> -- Configuring incomplete, errors occurred!
- [cgal-discuss] Building Poisson_surface_reconstruction_3 example, Anthony Webber, 04/19/2021
- Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example, Sebastien Loriot, 04/19/2021
- Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example, Anthony Webber, 04/19/2021
- Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example, Maxime Gimeno, 04/19/2021
- Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example, David Rochera, 04/19/2021
- Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example, Anthony Webber, 04/20/2021
- Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example, Simon Giraudot, 04/20/2021
- Re: [cgal-discuss] Building Poisson_surface_reconstruction_3 example, Maxime Gimeno, 04/20/2021
