cgal-discuss - Re: [cgal-discuss] Offset Poisson reconstruction
  • To: "Kim ( via cgal-discuss Mailing List)" <>
  • Subject: Re: [cgal-discuss] Offset Poisson reconstruction
  • Date: Wed, 21 Apr 2021 13:37:50 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-hdrordr: A9a23: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
  • Ironport-phdr: A9a23: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
Hello,
Thanks for the report.
I did some tests with the cpp/data you provided. With the default parameter 0.008, I find out that the program never finishes (well, at least it does not finish after 90 minutes) on my computer. Is this the same for you?
If I use 0.01, then it does finish in a few seconds, but the output looks very weird (very random topology with many cavities) whereas the input is quite simple and should produce a rather simple mesh.
From my tests, it seems that the part that never finishes is not the Poisson computation but the meshing: I do not quite understand the `signedDistance()` function that you use as a criterion, but my guess is that the problem comes from it. What exactly are you trying to mesh with this function?
Best,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 19/04/2021 à 21:37, Kim ( via cgal-discuss Mailing List) a écrit :
Dear developers,
Upon further testing it seems the underlying issue leading to the assertion
violation in Refine_facets_3.h (Line 862) was not really resolved by the
recomputations of the normals.
I have created a minimal example, which I have uploaded to the link bellow,
in the hope you can reproduce the problem and hopefully point out if I am
doing anything wrong. The minimal example should fail with its current
settings, and work without any issues if me_facetDistance (Line 92) is set
to 0.01.
test.7z <http://cgal-discuss.949826.n4.nabble.com/file/t376247/test.7z>
Regards,
K
