cgal-discuss - [cgal-discuss] Union result
  • To:
  • Subject: [cgal-discuss] Union result
  • Date: Fri, 30 Apr 2021 02:24:11 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-hdrordr: A9a23:pbqQKaCvs2GfzirlHell55DYdL4zR+YMi2QD/UZ3VBBTb4ikjMiohvsWzlvZjzwWVXEml7m7Scq9aFnb8oN45pRUAKe6UGDd2FeAAYl+4eLZqQHINDb58odmuJtIV4hbJJnOAUNhjcD8iTPYL/8FzMOc+K6lwcfypk0DcShQZ6tt7xh0B2+geyUceCB9GZE7GJCAj/AomxOcfx0sAviGOg==
  • Ironport-phdr: A9a23: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
Dear CGAL team,
I have got some questions and would be appreciated if you could help.
1. I am using the corefine_and_compute_union function. Is this function
working if the output is non-2-manifold? (in case the union of two
2-manifold meshes is a non-2-manifold mesh)
2. I have got a mesh (OFF file) including different shells (different
geometries). Is there any function for splitting the mesh into shells and
getting the geometry for each shell?
Thanks in advance.
Best regards,
Ali
  • [cgal-discuss] Union result, AliiAsgharii, 04/30/2021
