- To:
- Subject: Re: [cgal-discuss] Multithreading with CGAL
- Date: Tue, 29 Jun 2021 13:30:41 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:cqW1aa3dtq6utSgZ9jBS8wqjBIskLtp133Aq2lEZdPU1SL3gqynKpp4mPHDP+VMssR0b6LK90ey7MBDhHP1OgLX5X43SODUO0VHAROpfBMnZowEIcBeOkdK1u50QFZSWy+edMbG5t6vHCcWDfOrICePozJyV
- Ironport-phdr: A9a23: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
You can try this branch:
https://github.com/CGAL/cgal/pull/5402
It fixes the thread safety issue and should make it soon into the master branch.
Best,
Sebastien.
On 6/24/21 3:31 PM, Rasal Raj, Anish wrote:
Hello ladies and gentlemen,
I am trying to parallelize CGAL triangle intersection using OpenMP. I am using both do_intersect() and intersect() functions. The Kernel I am using is Exact_predicates_exact_constructions_kernel.
Now my question is, "Is the CGAL Intersection functions Threadsafe in the Exact_predicates_exact_constructions_kernel Kernel?".
If it is not "Is there a way to parallelize the intersection process?"
Thanks and Regards,
Anish R
- [cgal-discuss] Multithreading with CGAL, Rasal Raj, Anish, 06/24/2021
- Re: [cgal-discuss] Multithreading with CGAL, Sebastien Loriot (GeometryFactory), 06/29/2021
