- To: "" <>
- Subject: Re: [cgal-discuss] mesh generation with sizing functions/fields
- Date: Mon, 5 Jul 2021 17:41:25 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=uit.no; dmarc=pass action=none header.from=uit.no; dkim=pass header.d=uit.no; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=hJ+BnggANVCad0ufbT1qqEUm9zWL/huDBBiuZmaur74=; b=O6iDrtJL3/BUMSPTWOibK4a1o32PoHli1/8IuPS5IXsBOlYAV9xdD5YbN+tU2LY/oPNVfjFKQ9HQjeja97clKtGerOsNWjw0L+Z+oev49agR/RdGhMdQdmWk7aPVPg0YhmKz/gnyJ6E85tEh7aigG70D//orEb38LOTuHb+qBhmhVEremADYmrbfwLT2jDolm+bXsoq7QEmM+W2FQbtifX6seAjAjOlsoR3n2CJ0tUG8CMf3zKNKd5lSZb7fE/HwRKzfnn5gvEzRL1CX3rmnphW3gjpEcke4WRK5CawC4bsL8PDS6T9rZgfOHj23jDfqJP4HTWS9Cc1rhnNpmRFfeQ==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=O+ry8bqZ3rrDVGC4ZJ3rP5owKVpZd6mowGXzLUv+Ozx6xc7d85bnT48WncwhMtQI10Ntk3+md4gqxyc6MNR27plgIxzLFt7rJu+azxzSVJm2SpIokXV52//JDcyKYLFHzG15EIndUIWeuOS7PIgv3Pvh8GKFtgANi/1elmFWa9c6QBRmAjyG65yWUY8tTEt4C58aVb855EdP3mGiuClPeqebLNSdeBMdhKSuVfU5RTjIsouUv+RfByCSoKNumQXQZoEEzcvoilHJcxPShYWIgxUKcCOncMUsVPwYAHcuuW9LCsZMXQXBsMArQSb2tlCeyX9Zbf5DNZgj6Oknn515Pw==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-hdrordr: A9a23:Q+ReOK9amQ4/WIVMJ5Buk+FHdb1zdoMgy1knxilNoENuH/BwxvrFoB1E73TJYW4qKQkdcKO7SdK9qBTnhNNICOgqTP2ftWzd1FdAQ7sSibcKrweAJ8S6zJ8l6U4CSdkzNDSTNykcsS+S2mDRfLgdKZu8gcaVbIzlvhRQpHRRGsRdBnBCe2Sm+yNNJDVuNN4cLt6x98BHrz2vdTA8dcKgHEQIWODFupniiI/mSQRuPW9o1CC+yReTrJLqGRmR2RkTFxlVx605zGTDmwvloo2+rvCAzAPG3WO71eUWpDKh8KoCOCW/sLlWFtzesHfsWG2nYczHgNkBmpDt1L/tqqiKn/5vBbU015qbRBDOnfKk4Xic7N9p0Q6s9bbQuwqeneXpAD09EMZPnoRfb1/Q7Fchpsh11OZR03uerIc/N2K3oM3R3am9a/hRrDvCnZPiq59hs1VPFY8FLLNBp40W+01YVJ8GASLh8YgiVO1jFtvV6vpaeU6TKymxhBgm/PW8GnAoWhuWSEkLvcKYlzBQgXBi1kMdgMgShG0J+p4xQ4RNo+7ELqNrnrdTSdJ+V9M1OA7Ae7rDNoXpe2OGDIu/GyWXKEg3AQO+l3es2sRK2AiDQu158HIdouW/bG9l
- Ironport-phdr: A9a23:PcZWaxagfXxPNdJmZlqIjfv/LTGM14qcDmcuAnoPtbtCf+yZ8oj4OwSHvLMx1Q6PBtqHoKIfw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHcBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94DXbglSijewY7x/IBq1oAjfq8IbnZZsJqEtxxXTv3BGYf5WxWRmJVKSmxbz+MK994N9/ipTpvws6ddOXb31cKokQ7NYCi8mM30u683wqRbDVwqP6WACXWgQjxFFHhLK7BD+Xpf2ryv6qu9w0zSUMMHqUbw5Xymp4qF2QxHqlSgHLSY0/mHJhMJtkKJVrhGvpxJ9zI7VfI6bO/Vxc7jBfdMDWWZNQtpdWzBfDo66coABD/ABPeFdr4Tlu1UBtwaxBQ6yBOz1zD9Dm2L70rch0+Q9DArL2xYgEMgTv3TTstX6LqESXfquw6bS1jXDc+hb2Sr86IjUaBwhp/aMUKt2fMHMxkYhCxnLgU+MqYz5ITyVzOINvnCb4ud9W+yjlmwqpQ9srjWh28ohlJTEipwUx13A6Ch03Yk4K9OkRUNnYtOoDYZcuiCZOoZ3Qs4sQ2FltTo6x7AJv5OwYSYEyJMixxHFavyHdZCF4h3iVOaNITd4mWlqdKijiBa19Eis0vHzVsau31ZOtCZFlcPMtn8V2xzS7MiHUPp98V271TaBzQDe7PxPL0MslafDJJMt3qQ8mocPvUnBBCP6hlv6ga+Mekk55OSk9fzrb7b6qpOGKoN5hQ/zPr4zlsG9Bek0KBYCU3WD9eii1bDv4UP0TbBXgvEqiKbUsZXXKtoGqqKlBgJZz5ss5hO6Aju7ztgVm2QMIkhfdxKdlYfpPknDIPDmAve7hFShiC9lyenaMLH9H5nBN2XNn7j9cbpk7E5T0xQ8wcpY55JJFrEOO/XzWlL3tNPFFBM5Kxa0w+H7CNpjyoweRWOPAqifMK/Itl+I+/4vI+2LZI8SuzbxMeQq5/nrjXMhmF8de7em3YcPZX23AvhqOViVbWbuj9sbD2sGoAozQPb3hFGcTzJff3OyULg95jE/BoKmF4DDRoW1jbybxii0A5pWZn5cBVCKC3vnbJ+LW+wQaC+JP89hkyAEWaKnS48mzR2urhP1y6J7LurI/S0VrY7s1Ndv6O3XjB096D10D9+B3GGQVGF0hXgFRyQ23aB6uUxy0E2P0al+g/xCFNxc/elFUgkgNc2U8uphFtqnWh7dZszbDxG9U9C+CHcwSMgwypkAeQFmCtC6h1fC2SStRLQanrjOCJ0v+b/HxCvMId1gwUrLxLV0j0U6WtAdciq9l6tn/k7SAZTImgOXjeGxZKEE1WnM8mmEimGBtUUdXA9rWrjeRiMjYR6cptvw4gbOTqSlFK88GgpH08+LbKVQIJW9hlpPQLLvOc/Vfnmqs2a2HxeBgL2WOtnEYWIYiR/UBE8amgZb13+dKUBqHC6tpHzXCnpkHEnzS17t7a94ryXoHQcP0wiWYhg5hPKO8RkPiKnEIxvy9pQjgn947g5KRBO61d+QDMecrQ18eqkaeck6/FpMyWPesUp6I4CkKKdhwFUZdlYu16sL/wh2FsNGlppyxJvF5BdzNeSe1wEYHw4=
dear Sebastien,
thank you so much for the pointers!
best regards,
radovan
________________________________________
of "Sebastien Loriot (GeometryFactory)" <>
Sent: Thursday, July 1, 2021 10:12 AM
To:
The particular case you point is using the sizing field in this file:
https://github.com/CGAL/cgal/blob/master/Mesh_2/include/CGAL/Mesh_2/Lipschitz_sizing_field_2.h
It is not documented but it is tested in this test:
https://github.com/CGAL/cgal/blob/master/Mesh_2/test/Mesh_2/test_lipschitz.cpp
HTH,
Sebastien.
On 6/17/21 6:09 PM, Radovan Bast ( via cgal-discuss
Mailing List) wrote:
> dear all,
> [I am relatively new to CGAL and new to this list]
> Thanks so much for this super useful library!
> I am using 2D Conforming Triangulations and Meshes [1] and would like the
> triangle size to follow a sizing function.
> In short, after a bit of trial and error I managed to do something like the
> two left butterflies on slide 25 in presentation [2] but I am struggling
> with creating any working code that uses a sizing function (right butterfly
> on slide 25).
> I would very much appreciate if somebody could point me to the source code
> which generated that figure or any example that demonstrates this feature
> which I could adapt for my use case. Any pointer will be appreciated. I
> have spent quite a bit searching for this and also trying to reconstruct
> this from looking at the CGAL source code but after many hours doing that,
> I though I'd ask :-)
> thank you!
> radovan
> [1] https://doc.cgal.org/latest/Mesh_2/index.html
> [2] https://www-sop.inria.fr/geometrica/courses/master-vim/cgal-meshes.pdf
- Re: [cgal-discuss] mesh generation with sizing functions/fields, Sebastien Loriot (GeometryFactory), 07/01/2021
- Re: [cgal-discuss] mesh generation with sizing functions/fields, Radovan Bast, 07/05/2021
