Re: [cgal-discuss] Slivers seem to fool the location algorithm in CGAL Delaunay_triangulation
- To:
- Subject: Re: [cgal-discuss] Slivers seem to fool the location algorithm in CGAL Delaunay_triangulation
- Date: Sun, 18 Jul 2021 09:57:33 +0200 (CEST)
- Ironport-hdrordr: A9a23:2t2JD6pCBa0u4TBNFfmlcTgaV5o0eYIsimQD101hICG9E/bo9fxG885x6faZslwssTQb9+xoW5PwIk80l6QV3WB5B97LYOClgguVxedZgLcKqAeOJ8SRzIJg6Zs=
On Sat, 17 Jul 2021, Renaud GILLON wrote:
Using the CGAL d-dimensional Delaunay_triangulation class with the
Epick kernel, I want to generate triangulations in order to perform
barycentric interpolation of a multi-dimensional function sampled along
with its derivatives at the location of the vertices of the triangulation.
Because of the nature of the sampled function, the sampling grid is rather
anisotropic (the spacing in one direction is 1.0E4 times larger than in the
others) in some region. Despite this difficulty, the Delaynay mesh is nice
(uniform volumes) on the inside. It just has slivers (quasi-zero volume
cells) on the outside.
Initially, I was hoping to push the slivers out by adding "padding" (dummy
points) on the periphery where the slivers are occurring, so that test
points would always reside in a well formed cell.
However, I noticed that slivers seem to behave as "strange attractors" for
the point location algorithm. A large number of test points located close
to the boundary gets located in slivers, despite the fact that normally
none of these points should fall in there. The number of points that the
locate() method assigns to slivers is also totally out of proportion to the
fraction of the outer shell occupied by the slivers.
So the impression is that the slivers are somehow fooling the location
algorithm. *Could it be that the "inside / outside" detection depends on
the sign of some computed quantity (something related to a matrix
determinant) and that in the case of slivers, the result should be "zero"
but is not due to numerical errors and that the location algorithm then
"concludes" that the point is inside the sliver -- which is not the case,
just a results of bad conditionning ?*
Is there a way to specify a threshold value for the quantity used to make
the "inside / outside" test so that the problem related to slivers can be
avoided ?
Hello,
the computations are performed exactly, as if in infinite precision, so that's unlikely to be the problem. It is possible that there is a bug in the logic of the walk that affects degenerate cases, but I don't have enough information to say if that is the case, you could also be misinterpreting the result. Do you think you could prepare a testcase that demonstrates a point badly located? Please try to minimize it (low dimension, few points, short code).
Marc Glisse
- [cgal-discuss] Slivers seem to fool the location algorithm in CGAL Delaunay_triangulation, Renaud GILLON, 07/17/2021
- Re: [cgal-discuss] Slivers seem to fool the location algorithm in CGAL Delaunay_triangulation, Marc Glisse, 07/18/2021
- Re: [cgal-discuss] Slivers seem to fool the location algorithm in CGAL Delaunay_triangulation, Renaud GILLON, 07/25/2021
- Re: [cgal-discuss] Slivers seem to fool the location algorithm in CGAL Delaunay_triangulation, Marc Alexa, 07/18/2021
