cgal-discuss - Re: [cgal-discuss] CGAL 5.3 missing file config.hpp ?
  • To:
  • Subject: Re: [cgal-discuss] CGAL 5.3 missing file config.hpp ?
  • Date: Mon, 4 Oct 2021 09:28:39 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23:zJbv16/k20ZhiMO/0XFuk+D7I+orL9Y04lQ7vn2ZOiYlD/Bw8Pre4MjztCWE8gr5PUtLpTnuAtjnfZqxz+8Q3WBVB8bYYOCEghrREGgB1/qE/9SIIUSXnY5gPOVbAs1D4bXLbGSS5vyKgzVQfexQouVvvJrY/Ns2DE0AceipUcxdBstCZTpz23cZeDV7
  • Ironport-phdr: A9a23:2cQCTha5jqrdvGbD19EKjHv/LTF614qcDmcuAnoPtbtCf+yZ8oj4OwSHvLMx1gePDNyQtq0MotGVmpioYXYH75eFvSJKW713fDhBt/8rmRc9CtWOE0zxIa2iRSU7GMNfSA0tpCnjYgBaF8nkelLdvGC54yIMFRXjLwp1Ifn+FpLPg8it2O2+5YHfbx9MiTagbr9/LBe7phjNu8cLhodvNrw/wQbTrHtSfORWy2JoJVaNkBv5+8y94p1t/TlOtvw478JPXrn0cKo+TbxDETQpKHs169HxtRnCVgSA+H0RWXgLnxVSAgjF6Bb6Xortsib/q+Fw1jWWMdHwQLspXzmp8qVlRwLyiCofKjA37m/XhMxzgqxVrh2uqB5wzJLbboyOKPpzfbnQcc8GSWdPXMtcUTFKDIOmb4sICuoMJftWoJfmqFQUthu+GQisC/3pyjRVgHH22rc60+UmEQHawQctGMkOsHDTrNXvNacSVvy1wLPNzTXHdP5W1jL955LJchAlu/2DQbVwcc/IxEQpCgjKgUmep5b/MDOJyuQCrXKb7+x4WO6xi2AqtwJ8rzugy8ojhYTEgp4Yx03a+Shk3oo4K8C0RFB4bNK5DZZdtC6UOol5TM4hQGxlpCk3x74YtJC1YCUHzoksyRDYa/yCaYeI4xTjWf6NLjd3nn1lfKizhxGo8Uiv0uH8V8+00ExLriVfiNXMuGoN2hrO4caEUvtw5lmt1SqL2gzJ6exJIVo4mbTFJ5I82LI9locfvVzAEyL1gkn6krKae0E+9uS29ejrfK/qqoGYOoJylwrwKL4hmtalDuQ9KgUOX3aU+eC71LD7+E32WrRKjvkvnqjXqpDWON0XpqC5DgNIyIoj5BG/DzCp0NQcg3YLNk5KeBWCj4TxOlHOJu73DeunjliyjDtmw+rKM77hD5nXMHTPjqrtcax95kJB0AYzyMpQ55NQCrEPOvLzXUrxucTDDh89NAy02efnCNJh1o8EXGKPBrSUMKzXsVCS5+IvJ/OAa5MSuDb4M/Ql/eLhjWclmV8BeqmkxYcYaH+iEfRiOkmWfHvsgswdHmcXpQo+V/fniEaCUD5Wf3a9Rbgw5jA9CIK8DIfMXJqhgLKb3HTzI5tNe2oTCkyQCWy6MMKfSvIUYWSTJNVgm3oKT/+6Woo53FavsgH9jLFoJ+6R9iwDvo/4z4tI4fbOny0/5SAhD9iBy3rfCCZvj2YQTnk32rp+qApz0BCYwK1girtZE9JUoPhGWwN/OZ/HxPFhEIPOXVfKcd6NDVqnWd67GioZT9QrwtZIbVwuNc+li0X40iCjGKMUmrrDIJsu86XAlyzqI8FnynHakqwlp1YjS8pLc2ahg/gspEDoG4fVnhDBxO6RfqMG0XuVnI9i5W+HvUUdTxQpFKuYBDYQYUzZqdm/7UTHHefG4VsPPQ5IyMrEIaxPOISBZbBuS/LqOdCYaGW0yT/YOA==
Hello,
This header is from the boost library.
See https://doc.cgal.org/latest/Manual/thirdparty.html#thirdpartyBoost
Best,
Sebastien
On 10/3/21 7:58 PM, JP HARMAND ( via cgal-discuss Mailing List) wrote:
Bonjour,
Je viens de télécharger CGAL 5.3 pour une installation sous XCode sur mac.
Les premiers include dans un ficher de test :
#include "CGALtest.hpp"
#include "CGAL/Exact_integer.h"
#include "CGAL/Filtered_extended_homogeneous.h"
#include "CGAL/Nef_polyhedron_2.h"
Donnent l’erreur suivante:
In file included from CGALTest/CGALtest.cpp:10:
In file included from CGALTest/CGAL/CGAL-5.3/include/CGAL/Exact_integer.h:17:
CGALTest/CGAL/CGAL-5.3/include/CGAL/config.h:127:10: fatal error: 'boost/config.hpp’
file not found
*#include <boost/config.hpp>*
En effet, le dossier boost téléchargé ne contient pas le fichier requis par  l’include du  fichier  config.h, ni en direct, ni en recursif.
Et une recherche de  fichier  dans le package CGAL5.3 ne trouve pas ce fichier ( *config.hpp)*
****Je vous serais reconnaissant de m’indiquer  la source du problème.
CDT
JPH
