cgal-discuss - Re: [cgal-discuss] Offset Poisson reconstruction
  • To: "" <>
  • Subject: Re: [cgal-discuss] Offset Poisson reconstruction
  • Date: Thu, 7 Oct 2021 08:16:35 +0000
  • Accept-language: en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=none; dmarc=none; dkim=none; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-AntiSpam-MessageData-ChunkCount:X-MS-Exchange-AntiSpam-MessageData-0:X-MS-Exchange-AntiSpam-MessageData-1; bh=WcKZWJy681j+e0qsVj2wJcXQJnMQZGxnj4FGEC0jUp8=; b=jxwIGphj+8sGk2BqQiKZpsrjTro5Ba2MQMuG+4aV+ezVk72Z97Wx6nxECBUL9N1BPUrFqv+p9E6thrAToRw69mE4PcVKEkmsKAyNnXYSPo0oCUlcUYMUHZ5CZgukvAGVLmTLNhSP76ZiFD1ViHcbRgKWcujHlmpF3b/3FQ7fKoRlhod7EgUUG1Qna1e56BSk1dmiQSdS+5dP7UQUjgfdn3LG0UsBECZYwHPxNaZ6yN356/Msf/QkTbXuXc6/bf4r+WFSOd746x+CuoH75EiqHDa9Q6Bzo6a2ypOe4XCJjdgos0OpSNL/+wtm7oLXbGyivkKzEYTHxDH2OqTwGzIPxQ==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=K5B8Nh7cltgcpJeGJciMLke1HJPg3Fk4pTZTfBVMHwmZEYxh8KQjXAv4uuE25KbecoSN7xwvasl8CO6+8l/WwhSXUIXOh0rpLCQM1UPz6miUxkifxLISBVxAM6jv8m/fVz8Ubz56PW1mB2eyAP9+LijZzXD5SLx7rA8Wu3LeHNjR5deHkFsuFZGEQBanbGr14YGnIRVzksdqFJpObwLOsmnVK9Hm8yyTbfPoUFYkiv5c/osURVsOfswpLzdto48Es82OL/qZGmMJMaQi+hNpTTCfQFciRtkz22cR0aGqVCkU0zNrivv9yFHzI5/mfQSHNiGtLBSRDecTeL6RlOJjhg==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-hdrordr: A9a23:cb6Zxaq1DYGXRRkF2KwwYxMaV5roeYIsimQD101hICG9Kvbo8fxG785rrCMc6QxhJk3I9urwWpVoLUmyyXcx2/h3AV7AZniWhILLFvAG0WKK+VSJcEeSmtK1l50QF5SWY+eQMbEOt7eY3ODOKbYdKbe8npxAzt2ut0uFBTsaEJ1I3kNCLkKcDlB5QglAC/MCZeqhDoAsnUvbRZw9Bv7Le0XsSYD41qH2fbzdEGE7OyI=
  • Ironport-phdr: A9a23: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
  • Suggested_attachment_session_id: 5d1171bb-4008-52a0-a25b-5137f8e23c33
Apologies for coming back to this so long after the last post but I forgot to get back to it sooner. In the end I discovered the assertion violation I was getting occasionally is caused by requiring the mesh to be manifold, i.e. "F_C3t3 c3t3 = CGAL::make_mesh_3<F_C3t3>(domain, criteria, CGAL::parameters::manifold() );: . When I don't use the tag CGAL::parameters::manifold() the error disappears. Just letting you know in case its not how it is suppose to behave and you want to look further into this.
Best,
K
Sent: Saturday, April 24, 2021 2:51 PM
To: <>
Yes probably. Since you are modifying the function to be meshed I was
looking at what could be an issue for the mesher. The bounding volume
is one of them.
Sebastien.
On 4/21/21 3:40 PM, Kim ( via cgal-discuss
Mailing List) wrote:
> I compute the bbox of the points used to create the Poisson reconstruction
> and add a padding of 10% the size of the unit cell. Since these points are
> the outer bounds of the domain to be meshed this should be safe with the
> current unit cell size (I recognize that for very small unit cell sizes it
> may be to little). To be sure, I just increased dramatically the bounding
> box and I get the same behavior. Shouldn’t I expect the error to appear
> regardless of facetDistance if the bbox was the problem?
> Best,
> K
> Sebastien Loriot (GeometryFactory) wrote
>> Since you are changing the implicit surface to mesh, did you make sure
>> that the bbox is large enough to contain the output?
>> Best,
>> Sebastien
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
  • Re: [cgal-discuss] Offset Poisson reconstruction, F.A. Perez, 10/07/2021
