cgal-discuss - Re: [cgal-discuss] How to read a PLY with properties as Point_set_3
  • To: "Yaoyu Hu ( via cgal-discuss Mailing List)" <>
  • Subject: Re: [cgal-discuss] How to read a PLY with properties as Point_set_3
  • Date: Thu, 21 Oct 2021 08:10:03 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-hdrordr: A9a23:dH5xLarxrOH0x3i+4n25S48aV5oVeYIsimQD101hICG9E/bo8vxG+c5w6faaslgssQEb9OxoR5PwOU80maQU3WBpB8baYOCEghrLEGgB1+TfKlTbckWUmtK1vp0AT0ERMqySMbDF4PyKhDVRr7sbsb+6GB/Ev5a480tQ
  • Ironport-phdr: A9a23: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
Hello,
At least on Windows if you read a binary ply file you must open the stream in binary mode.
Can you try    std::ifstream ifs(fn, std::ios::binary);
Best,
Andreas
On 10/21/2021 1:20 AM, Yaoyu Hu ( via cgal-discuss Mailing List) wrote:
Hi,
I am trying to read a binary PLY file as CGAL::Point_set_3 but I can't get it right.
I am using CGAL 5.3.
I suppose there is not a dedicated example showing how to read a PLY file as Point_set_3 that has properties. For my PLY file, there are point normal and color stored. The code I tried to read it as CGAL::Point_set_3 is as follows:
=== Code begins. ===
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel_t;
typedef Kernel_t::Point_3  Point_t;
typedef Kernel_t::Vector_3 Vector_t;
typedef std::array< unsigned char, 3 > Color_t;
typedef CGAL::Point_set_3<Point_t> PointSet_t;
typedef PointSet_t::Point_map PS_PointMap_t;
typedef PointSet_t::Vector_map PS_NormalMap_t;
typedef PointSet_t::Property_map<Color_t> PS_ColorMap_t;
PointSet_t sr::read_ply_as_point_set( const std::string& fn ) {
    std::ifstream ifs(fn);
    PointSet_t point_set;
    // Default color.
    const Color_t color_black { { 0, 0, 0 } };
    // The color map.
    PS_ColorMap_t color;
    bool success = false;
    boost::tie( color, success ) =
        point_set.add_property_map<Color_t>("color", color_black);
    assert (success);
    // Read PLY.
    CGAL::read_PLY_with_properties(
            ifs,
            point_set.index_back_inserter(),
            CGAL::make_ply_point_reader( PS_PointMap_t() ),
            CGAL::make_ply_normal_reader( PS_NormalMap_t() ),
            std::make_tuple( PS_ColorMap_t(), CGAL::Construct_array(),
                             CGAL::PLY_property<unsigned char>("red"),
                             CGAL::PLY_property<unsigned char>("green"),
                             CGAL::PLY_property<unsigned char>("blue") ) ) )
    return point_set;
=== Code ends. ===
The codes that I am not sure about are the lines of CGAL::make_ply_point_reader() and CGAL::make_ply_normal_reader(), they are probably wrong but I don't know how to get it right.
Thanks!
Yaoyu
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
