cgal-discuss - Re: [cgal-discuss] Speeding Up Arrangement Insertion
  • To:
  • Subject: Re: [cgal-discuss] Speeding Up Arrangement Insertion
  • Date: Tue, 9 Nov 2021 01:28:29 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23:+CvSV6D9LP3sVmDlHemV55DYdb4zR+YMi2TDtnoBMCC9F/bzqynApoV/6faZskdyZJhko6HiBEDiexLhHPxOkO0s1N6ZNWGMhILrFuFfBODZslrd8kPFh4hgPGRbH5SWyuecMbG3t6nHCcCDfeod/A==
  • Ironport-phdr: A9a23:L95SSREqV6RoYbTxvEELA51GfxVLhN3EVzX9CrIZgr5DOp6u447ldBSGo6k31BmYBM6GtLptsKn/i+jYQ2sO4JKM4jgpUadncFs7s/gQhBEqG8WfCEf2f7bAZi0+G9leBhc+pynoeUdaF9zjaFLMv3a88SAdGgnlNQpyO+/5BpPeg9642uys55HfeQFFiCeybb5yLhi9sBncuNQRjYZ+MKg61wHHomFPe+RYxGNoIUyckhPh7cqu/5Bt7jpdtes5+8FPTav1caI4TadFDDs9KGA6+NfrtRjYQgSR4HYXT3gbnQBJAwjB6xH6Q4vxvy7nvedzxCWWIcv7Rq0yVD+/7alkVQXohT8IOD438m7ZisJ+gqFGrhy/uxNy2JTbbJ2POfdkYq/RYdEXSGxcVchRTSxBBYa8YpMAAeoPPOZTsonzp1wBrRSgAQmnGeTixSFGhn/306061OshHh/C3AE7ENIOtW7brNTxNKsITe+1y6zIwCzFYvhL1jjz9JLGfQo9ofGQQ71wa8zRxFEgGQ7Lk1idtZDpMTyL2uoDr2WW6/RtWOCshmI5qgx8vjaiy9syhoTLmI8byk3J+Dl2zos2OdG1SlB2bN+qHpZesSyRKoV4QsQnQ25yuSY6zKULtoK0fCcQzJQr3Rnfa+aIc4SQ7RLjVfqRITdlhH1+Yr6wmxGy8U24xu39UMm0yldKoTBfntnCrHABzwDc6s6dSvtm5Euh1yyP2gbO4e9HOUA5jbTXJ4Ilz7IqlZcesV7PEjHolEnolqObeUsp9+614Or9eLrmvIWTN4pshwH+LKsunsu/DPw9MgcUXmib/f2w1KD58kHkWblKgPI7n6fDvJDVIsQboaG5AwtL3Yo59xm/CDKm3MwZnXkBMl1FZAqKg5b1N1zKOvz1Dveyj06ynDt12fzKJLLsD5vVInjGirjhfLJ960BGyAo0yNBS/4xbCr8AIPL9XU/xu8LXDhsiPgy7xuboEtR91ocEVW2TBa+ZNbvesUWU6eI3P+mMeIgVtS7hJPgq/fHuiWY1lkIcfamywZQXdWu4Hu99LkWCYXvsh88BHn0Qsgo/SuzqklyCXiRJa3a8RaJvrgw9E5+sWIffWpi20vvGxza+BpQQZ2ZcC1nKH22vbJSBQ/5LaSScJYhqnTUAELSgUIQ8zgr9iQnh1rBHMu/Qry0EqYr4hp8y/PzWjRh09DpuDs3b3XvKVHBxhmpPRjk42+d0rkV5j1uCyqNlmOcLKNpI+vl1XxcmYJ7A0/RhWZe1QRPEZt7PSVC8Q9zgDyt2VcM029ZJYkBzHJKpgRnHmiarGLQIjKfYOJth+a3V2z39Jt121m3d/KgnlVgvBMVVZkO8gasq2gbST6DOnEid3/Kne6US2yHA8E+MyGOPuAdTVwsmAvaNZmwWekaD9Yex3UjFVbL7UdzP3SNOzMeDLu1Bbdi71D2upd/mMdXaJn+4wiK+WU3OybSLY47nPW4a2XeFYKDhuw8W9HeCcwM5A3X5y18=
Hi Bruno,
I second what Guillaume says.
Also, you can try a different point location strategy.
If you push code that actually compiles plus the input data file, I can run it and make a better assessment.
I don't want to spoil the party, but there is a big difference between disjoint segments and intersecting segments.
How many segments do the sets contain?
How many vertices does the arrangement have (how many intersections) ?
Best,
Efi
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On Fri, 5 Nov 2021 at 14:46, Guillaume Damiand <> wrote:
Hi Bruno;
Instead of inserting each segment successively, insert them "simultaneously" using the following insert free function:
https://doc.cgal.org/latest/Arrangement_on_surface_2/group__PkgArrangementOnSurface2Insert.html#ga744ea4ef5e40e521af139e106b6480f8
The complexity of the global method is almost in O(nlogn), while it is O(n^2) for the other solution.
cf. also https://doc.cgal.org/latest/Arrangement_on_surface_2/index.html#title68
Best
Guillaume
Le 05/11/2021 à 13:37, Bruno Silva a écrit :
Hi Andreas,
GitHub Gist: instantly share code, notes, and snippets.
Best,
Bruno
De: em nome de Andreas Fabri
Enviado: sexta-feira, 5 de novembro de 2021 06:51
Para: Bruno Silva ( via cgal-discuss Mailing List)
Assunto: Re: [cgal-discuss] Speeding Up Arrangement Insertion
Hello,
Ideally, you put code on gist.github.com
Best,
Andreas
On 11/5/2021 12:39 PM, Bruno Silva ( via cgal-discuss Mailing List) wrote:
Just sending the code once again with some small changes:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Arr_naive_point_location.h>
#include <CGAL/Arr_non_caching_segment_basic_traits_2.h>
#include <CGAL/Segment_2.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel                       K1;
typedef CGAL::Arr_segment_traits_2<K1>                                          Traits_2;
typedef CGAL::Arrangement_2<Traits_2>                                           Arrangement_2;
typedef CGAL::Delaunay_triangulation_2<K1>                                      Delaunay2;
typedef CGAL::Constrained_Delaunay_triangulation_2<K1, CGAL::Default, Itag>     CDT2;
typedef Traits_2::Point_2                                                       Point_2;
typedef Traits_2::X_monotone_curve_2                                            Segment_2;
typedef CGAL::Arr_naive_point_location<Arrangement_2>                           WalkPL_2;
int main()
    ExternalDataSet datas("data1.txt","data2.txt");
    Arrangement_2 arr;
    WalkPL_2 walkPL(arr);
    // first step of insertions
    std::chrono::steady_clock::time_point begin = std::chrono::steady_clock::now();
    std::vector<Segment_2> segmentSet1 = datas.externalData(0);
    CGAL::insert_non_intersecting_curves(arr, segmentSet1.begin(), segmentSet1.end());
    segmentSet1.clear();
    std::chrono::steady_clock::time_point end = std::chrono::steady_clock::now();
    if (verbose) std::cout << "Time spent - First Insertion: " << std::setprecision(6) << std::chrono::duration_cast<std::chrono::microseconds>(end - begin).count()/1.0e+6 << std::fixed << " sec." << std::endl;
    //Second step of insertions
    std::vector<Segment_2> segmentSet2 = datas.externalData(1);
    // #pragma omp parallel for if(_parallelOptimization)
    for(auto seg = segmentSet2.begin(); seg < segmentSet2.end(); ++seg)
        CGAL::insert(arr, *seg, walkPL);
    segmentSet2.clear();
    if (verbose) std::cout << "Time spent - Second Insertion: " << std::setprecision(6) << std::chrono::duration_cast<std::chrono::microseconds>(end - begin).count()/1.0e+6 << std::fixed << " sec." << std::endl;
    CDT2 cdt;
    // Constrained Delaunay package to triangulate the arrangement
    for (auto it = arr.edges_begin(); it != arr.edges_end(); ++it) {
        cdt.insert(it->source()->point(), it->target()->point());
    if (verbose) std::cout << "Time spent - Creation of the Constrained Delaunay Triangulation: " << std::setprecision(6) << std::chrono::duration_cast<std::chrono::microseconds>(end - begin).count()/1.0e+6 << std::fixed << " sec." << std::endl;
Att,
Bruno Rammon Silva Souza
De: Bruno Silva
Enviado: sexta-feira, 5 de novembro de 2021 06:20
Para:
Assunto: Speeding Up Arrangement Insertion
Hi everyone,
I'm having a problem with efficiency when computing arrangements by CGAL. Thus, I would like to know whether there's any way to improve the efficiency of this.
The code is:
int main()
    segmentSet1.clear();std::chrono::steady_clock::time_point
    // Insertion of the second set of segments
    // #pragma omp parallel for //Parllellization is not working!!
    for(auto seg = segments1.begin(); seg < segments1.end(); ++seg)
    // Section 2 - It is using the constrained Delaunay package to triangulate the arrangement vertices and constrained edges
        CDT.insert(it->source()->point(), it->target()->point());
I have two distinct sets of segments (std::vector<Segment_2> segmentSet1 and std::vector<Segment_2> segmentSet2 ) that comes up from external data. The segments in segmentSet1 don't intersect with others segments in this set. This is also true for the segments in segmentSet2. However, the segments in segmentSet1 certainly intersects with the segments in segmentSet2.
I insert the first set of segments by the function CGAL::insert_non_intersecting_curves(arr, segmentSet1.begin(), segmentSet1.end()). The insertions of the second set of segments are performed by the function CGAL::insert(arr, *seg, walkPL). The efficiency first intersection is pretty good, but the second one is very inefficient. After these insertions, a Constrained Delaunay Triangulation is created.
I would like to know whether there is a way to improve the efficiency of this second insection. I've tried without success to perform a parallelization of the loop in the second insertion.
Is there any way to parallelize this for-loop for the second insertion? Or should I try another approach to improve the overall efficiency?
Best,
Bruno Souza
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34                 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
