cgal-discuss - Re: [cgal-discuss] Union of balls and self-intersecting mesh
  • To:
  • Subject: Re: [cgal-discuss] Union of balls and self-intersecting mesh
  • Date: Tue, 23 Nov 2021 18:54:59 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-data: A9a23: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
  • Ironport-hdrordr: A9a23:2YlXMK8rCWq3xonSqtpuk+AyI+orL9Y04lQ7vn2ZHyYlC/Bw8Pre/8jztCWVtN9/YhodcLy7UpVoa0mskqKdg7N/AV7SZmjbUQKTRelfBO3ZrgEIcBeRygcy78tdmoFFeaXNJGk/o8bmxQGyV/493diA68mT9IHj5kYoYwF2Tqlqqz5jDAWWGFAefnglObMJULSd++9OrH6YYnIVYs6nQlkJNtKzwuHjpdbJYQMiDxVi0RKJjj+j9frCGwWYty1uNw9y/Q==
  • Ironport-phdr: A9a23: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
It should not happen. IIRC, it is the output from the Surface_mesher
so it should be clean.
Would you have a minimal example showing the problem?
Best,
Sebastien.
On 11/23/21 6:44 PM, Bruno Manganelli ( via cgal-discuss Mailing List) wrote:
Hi,
I am using the Union_of_balls_3 class and the mesh_union_of_balls_3 function.
However, in certain scenarios, the resulting mesh contains self-intersections (PMP::does_self_intersect(mesh) returns true).
Is this expected?
I can provide an example if required.
Thanks!
Bruno
