cgal-discuss - Re: [cgal-discuss] Fwd: How to do the nearest neighbor search on a Point_set_3 with properties
  • To:
  • Subject: Re: [cgal-discuss] Fwd: How to do the nearest neighbor search on a Point_set_3 with properties
  • Date: Fri, 4 Mar 2022 10:57:18 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-data: A9a23:+lHL4quo2AQMf1kJhLKN2OWsNefnVGFYMUV32f8akzHdYApBsoF/q tZmKWqCaPuPNzfyftkkboXg8E9XvpPQmoQ3TFZvqSoxRS0TgMeUXt7xwmXYb3rDdJWbJK5Ex 5xDMYeYdJhcolv0/ErF3m3J9CEkvU2wbuOgTraCY0idfCc8IMsboUsLd9UR38g52bBVPyvX4 Ymo+5aHZAf8s9JJGjt8B5yr+EsHUMva42twUmwWPZina3eD/5W9JMt3yZCZdxMUcKEMdgKJb 7qrIIWCw4/s10xF5uVJPVrMWhZirrb6ZWBig5fNMkSoqkAqSicais7XOBeAAKtao23hojx/9 DlCnbu9eFwOIqnXpKcMVAhYIhFiHZ1816CSdBBTseTLp6HHW37lwvErE0RveINEpqB4BmZB8 fFeIzcIBvyBr7jukfTrF6813JRlcJWD0IA34hmMyRnCCfE8QJffBaDOzdBd1TY0wMtJGJ4yY uJGN2I2PE2cC/FJElsPWKg8suLzv1fQSidJp0C1pqxpsneGmWSd15C0aIaPEjCQfu1ekU+c4 27H5G/kGQoyL82a0TPD83S2h+aJkzmTZW4JPLix9/ovn1jKg2JPVFsZUly0pfT/gUm7Mz5CF 6AK0g0jnPMV6EiwcprsWAy4kU6Yni4mdMUFRoXW9zqx4qbT5g+YAE0NQThAdMEquacKqdoCh g/hczTBVWwHjVGFdZ6O3uzL8m7qaED5OUdHNHBUF1JUizX2iNhr1kqnczp1LEKiYjTI9dzYx jmLqG0hguxWg5JXkaq8+l/DjnSnoZ2hou8JCuf/DjzNAuBRPtbNi2mUBb7zs6wowGGxEAPpg ZT8s5LChN3i9LnU/MB3fM0DHauy+9GOOyDGjFhkEvEJrmrxpSX4J9oIuGohfy+F1/ronxe5M Cc/XisBtPdu0IeCMMebnqrtUZ1xlfG4fTgbfqmNMIEeCnSOSON31Hg2ORT4M5HFn08rnqUyU ap3gu79ZUv2/Z9PlWLsL89EieFD7nlnmQv7GM6mpzz6juL2TCPEEd8tbQrVBshkvfPsiFuOq L53aZDaoyizpcWkPUE7B6ZIfQ5URZX6bLiqw/FqmhmreVI3SDl8UKaKmdvMueVNxsxoqwsBx VnlMmcw9bY1rSSdQelTQnw8Or7pQ7hlqnc3YX4lMVqyiiosZI+u6OEUcJ5uJesr8+lqzPhVS fgZepXYUq4fFGifozlNP4PgqIFCdQiwgV3cMiegZg85dcEySgHM/OjiYQaypjIFCTC6tJdlr rD5jlHbTJMPSh5MFsHTbP7znVq9sWJMyu13VkrMZNJUfRy0ooRtLiXwiN4xIt0NeU2TnGvEi 17ODE5B9+fXooIz/N3Yvoy+rt+kQ7lkA05XP2jH9rLpZyTX+2yUx4UfAuuFeDbqUnytpPeva OBT+PHLMPMdmWFMvYchQa1gyrgz5oe2qrJXklZkEXHMYwj5A79sOCPdj8xGt6kI2boA/AXqB gSA/d5VPbjPM8TgSQZDKA0gZ+WF9PcVhjiCsqhvcRuivHd6rOidTEFfHxiQkygBfrF7B4Uon LU6s8kM5g3j1xcnboScgiZP+zjeJ3AMSf985JQTAYuulQ9yj18ePdrTDSj55JzJYNJJaxF4L jiRjavEprJd2kuSLCZpRCaVhbJQ1cYUpRRH7F4ePFDVyNDLsfk6gU9K+jMtQwUJkxhK3oqf4 ISw25GZ+ElPw9tpuCSHd2WlGgUEGxjAv0Ktlx0Gk2rWS0TuXWvIRIH41SBh42hBm1+wvBACl F1b9IoheTnvdcD1mCA1XCaJbtT9GMdp+FSqdN+PRqy48lpTXdYhqqCrbGsM7RDgBKvdQaEBS fZCpI5NVEEwCcLcT2DXxWVXOXT8hS1o/FB/fMw=
  • Ironport-hdrordr: A9a23:1A9apKDRAgkt7wblHemP55DYdb4zR+YMi2TDpHoBLyC9Ffbo6/ xG/c5rqCMc7Qx6ZJhOo6HjBEDtewKmyXcx2/hqAV7AZniChILLFvAA0WKK+VSJcE3DH6xmpN 9dmsBFaeEYZmIK6voSjjPIaurIjOP3lJxARt2z856ud2xXgm1bgDuRwzz0LnFL
  • Ironport-phdr: A9a23:rmAYNR9z6Uzzzf9uWWO1ngc9DxPPW53KNwIYoqAql6hJOvz6uci4Z gqGvaUm1A6BdL6YwsoMs/DRvaHkVD5Iyre6m1dGTqZxUQQYg94dhQ0qDZ3NI0T6KPn3c35yR 5waBxdq8H6hLEdaBtv1aUHMrX2u9z4SHQj0ORZoKujvFYPekdq72/qv95HPYAhEiyaxbLdvJ xiqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4U KdXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7S60/Vza/4 KdxUBLmiykJODE3/2/KlMJwgqJVrxC9qBJw2IPUfIKYOeBicq/Bc94XR2xMVdtRWSxbBYO8a pMCAfcfMulDtYb9vEcOrRqgCgmqGejhzDhIhmX33a09z+QqDAbL3BckH9IJqnTUrdL1NLsIX eCwyKnF1jrDb/ZM1jf87IjEaAwuofaJXb9pd8fa1EYgGR/fgFqKtYzlIy2a1v4Ls2WD8udtV +Oihm8ppQxxozWj2MQhh5XJi48I11zJ8St3zoY6K9O4TEN2b9GpHZRUuiybOIZ4QswsTmN1t Sg6xLALu5i2dzUExpQgwh7Qcf2Hc46Q7xLsVeaRPTd4hG9+d76lmxmy9k2gxvXgWcm7yllKq jBJkt7WtnACzxDT686HSuF8/ki7wzqP2RrT5+dZKk43jarWM4AtzqI0m5YJsknOHjX6lFjog KKVbEkp9eel5/zkb7jlvJOQKZJ4hwXkPqkvmMGzG/k0PwoMUmWd5O+yzqfs/VfjT7VPlvA2k rfWsJTdJckDo662GQ5V0oI65xexCjeqzc0UnXcIIV9KYh6HgI/pO1bBIPD8E/izmUijkDBux /zeP73hBIvCLmTbnbv/Ybpw71RQxQkzwNxF+p5YFLIMLOj8V0L+rNDYCwU2Mw2ww+bpEtV90 YYeVHqUAq+dN6PSq16I5uUzI+WWYY8VvC3wK/cg5/H0jH85nUURcrWu3ZsScHy4GO9pLF2DY XXwmtcBDXsKvg0mQeD3kFGCSyJcZ26uX6Ig4TE2EJ6pDYjZSYCpmbCOwSa7HoZKaWBbEVCMC mzld56EWvcJcCKdONVtkj0CVbi7So8uzwuitAHgy+kvE+zP5ydNtY7/zMMnoKrIhBQq/Hp1C d6c2ieDVSZvj2YQTng32q545kdyw1PG3aljiOFDDo9u4ehUWDs3JYKJz/BmE8ugHUXab9KRQ RCnRM+nCHc/VJUq0toWagF8HdulyRvM1i7vD74OnKGQH88I9ffX0HH1Ysp80H3bz7IJjl88Q 8IJO3f1qLR48l3oCoTAiFmYmqDiUaMG3SnRvDOYyW2UvUZEFgt0earAVHEbIEDRqIKqtQv5U 7ayBOF/YUN6wsmYJ/4SAjWIpVBPRfO4fc/bf3r0gGCoQxCB2rKLaoPuPWQbxiTUTkYewEgI5 XjTEw84C2+6pn7GSiR0HAf0Z0T28O5i7na/ZkAxxgCOKUZm0un94QYb0MSVUOhbxbcYoGEko jRwEky62ofND92apg19OqBYSdw46VZDk2nesl81JYSueoZlgFNWaAFrpwXu2hFwX51HitQvp Wg2wRBaLKuZ1BZecmrd08ysfLLQLWb28VakbKu+Nkj29tGQ9+9P7f05rw6mpwS1Dg859G0h1 dBJ0nya75GMDQwIUJu3XFxlvx5976rXZCUw/ea2nTVlLLW0vzne2tkoGPptyxCueM1aOb+FE wm6GtMTBsynIugn01azaRdMMOdX/a8yd8SoEpnOkLWvO/xhmy7giGBv74V000bK/C15C6bJ0 5sD3/CEz16fTT6vxFyls83xhcVFfWRIRjv5mXWiXdQBIPEuLuNpQS+0Lsa6x8tzncvoUn9cr xu4Ak8endSuYVyUZkD82gtZ0QIWp2amkG221W8R8Xlho6yB0SjJ2+mnegAAPzsBX21ll1brP c6xi/gVWUGpa04ikx7vtiOYj+BL4b9yKWXeWxICZCzxNWBlTu21spKNZsdO7NUjtiAdA4HeK RiKD7X6pRUdySbqGWBTkSs6ez+dsZL8hxVmiWiZIR6ftVLhcNprjVfa7d3YHrtK2yYeATJ/k X/RD0S9ON+g+ZOVkY3Cu6awTTDpWppWeCjthYSO0UnzrXZuBge+mOz1n9nPHg0z0Cu93N5vH SnFtxfzZID32r/ya7o2OBk1Qgamu4wmRsl3icMoiYsV2GQGi5nwnzJPimr1PdhBmOr/YHcLW T8X0ovQ6Qnh1ldkKyHBzIb4W3OBh8p5MoPiMyVGh2RktZAMVPvHid4M1TF4qVe5sw/LNP10n zNGjOAr9GZfmOYR/gwk0iSaBLkWW0heJy3l0RqSvLXc5O1aYniidb+o2Q9wh9ekWfuZpgZGW XHlPJImNSB158R7dlnL1Tegj+OsMMmVdt8VuhCOxl3bi+9PKZUt0P8OrSViMGP5+3YizqRo6 H4mlYH/t4+BJWJ3+au/CRMNLTz5afQY/TT1hLpflMKbjMi/W49sETIRUN70XOqlRXgM4O//O V/EQ1he4j+LXKDSFgiF5AJ6omLTRtq1YmqPKiBRzM0+FkLAYhUO2EZOAGp8xtljSkir3JCzL hs/vGtKoAem8l0Ujbs5Unu3GmbH+FX2NHFtEMLZdFwOqVsar0bNbZ7AsKQpQ3AersXn9EvXc iSaf1gaUjtPAxDCXgG5eOHpvImlkaDQB/LifaSSJ+zU9KoGEa/PnMzn05M6rW/UZoPWYSYkX 7tjnRAaFXFhR5aAxG5JEn1L0XqLN4nC+nLesmV2tpztqqy6HlKyo9LVW/0KdowwsxGu3fXZb rDW2XY/cGcCkMtLnC6AyaBDjgRL1Wc0LGjrSu5G7WmUHcey0udBBhofIUufLeNu6KQxlklIM M/f0Zbu06Jgy+UyExFDXEDgncegYYoLJXu8PRXJHhTDMrPOPjDNz8ztBMH0AbRNkOVZsQGxs jeHAgfiODqEjTzgSxGoN6lFkiiaOBVUvIz1fAxqDCDvS9fvaxvzN9ES73V+2bovmnbDLnIRK xB5ekJJ66KVtGZW3qk5FGtG4X5oa+KDnmfR7uXVLIoXreo+AilwkLE/gjxywL9U4SdYAf1tz XGK/5g+/hf/yLnJlmY0NXgG4ixGj4+Ko0h4bKDQ950bHG3B4ApI9mKITRIDu9piDNTr/aFW0 NnG0qzpe1Igu5rZ+9URA8/MJYeJKn0kZFDyHDnODQwZCzuvHW7ajk1Z1vqV8zfGy/py4oipg 5cIRrJBARYtEegGD01+ANEYCJJ+XzdhjrvCycBUuTyxqx7eQMgctZfCHKH3Y72nOHOSir9KY AENyLXzINEIN4H17Edlb0FzgIXAH0e4tT9lrShobwtyq0JIoiEWpogb1Efsawfr63gWR6bcd v8ejwJ/ZaEy8W6p7QtrYFXNoyQ0nQ86ntC32Vis
  • Ironport-sdr: jfPlDCnHOX+sJjIHEtQu5fwlHPhwBRX4U0MmoroLiwVuDmMk8ELitkQqjEzFOy37qeYm8h2azt BP00itbPd1YhmafZICJjgKpFYQgDCzNcLTV2WbZiBWSYmTfA4Q42cClVAff1Bh5TWr/ggVGDGU myIEsG1gZlhrfpsFol78WqK/IynFG2x2BXXCRTLCymKeC7Z4hOkIECqO5XYf2D+suO0od0BFsb Vw1wjTQ124lDzXdKM6W0QqwE9KO/VnHv0OmIIQqtJQIxCBGDOsWT+0u7lbYsGbItGSifIvRgRs D9VGcQ+JRDoHDqjEoP2KMDfo
Could you please explain why you think there is a bug, with as assertion for example?
Thanks,
Sebastien.
On 3/3/22 04:06, Yaoyu Hu ( via cgal-discuss Mailing List) wrote:
I was so dumb that the compiling error in my previous email is due to a typo.
I have updated the sample code, now it compiles. Get the updated code here
https://gist.github.com/huyaoyu/6bd9e6b54bc895b7fadebe3863456e92 <https://gist.github.com/huyaoyu/6bd9e6b54bc895b7fadebe3863456e92>
Now I have a new problem. If I run the code, I got the following outputs. It seems that the search does not work for me. I must have done something wrong.
========== Outputs. ==========
Hello, test_point_set_nearest_neighbor!
index = 0, point: [ 0 0 0 ], color: [ 100, 100, 100 ]
index = 1, point: [ 0.1 0.1 0.1 ], color: [ 101, 101, 101 ]
index = 2, point: [ 0.2 0.2 0.2 ], color: [ 102, 102, 102 ]
index = 3, point: [ 0.3 0.3 0.3 ], color: [ 103, 103, 103 ]
index = 4, point: [ 0.4 0.4 0.4 ], color: [ 104, 104, 104 ]
index = 5, point: [ 0.5 0.5 0.5 ], color: [ 105, 105, 105 ]
index = 6, point: [ 0.6 0.6 0.6 ], color: [ 106, 106, 106 ]
index = 7, point: [ 0.7 0.7 0.7 ], color: [ 107, 107, 107 ]
index = 8, point: [ 0.8 0.8 0.8 ], color: [ 108, 108, 108 ]
index = 9, point: [ 0.9 0.9 0.9 ], color: [ 109, 109, 109 ]
Found nearest point of 0 0 0:
index = 6, distance = 0, point: [0.6 0.6 0.6 ]
color = [ 106, 106, 106 ]
========== Outputs end. ==========
Any help is appreciated.
Thank you!
Yaoyu
---------- Forwarded message ---------
Date: Wed, Mar 2, 2022 at 6:07 PM
Subject: How to do the nearest neighbor search on a Point_set_3 with properties
To: < <>>
Hi,
On CGAL v5.4, Ubuntu 20.04, g++ 9.3.0.
I'm trying to do the nearest neighbor search on a Point_set_3 object by "dD Spatial Searching". The Point_set_3 has a property for point color. I am trying to follow the example "Using a Point Property Map of a Polygonal Mesh " https://doc.cgal.org/latest/Spatial_searching/index.html#Spatial_searchingUsingSurfaceMesh <https://doc.cgal.org/latest/Spatial_searching/index.html#Spatial_searchingUsingSurfaceMesh>
The reason for referring to the above example is that I suppose points and colors are saved as property maps in Point_set_3 objects and I need to get the Index of a point from the Point_set_3 object, such that I can use the Index object to retrieve a color object saved in the property map. It looks like the relationship between mesh vertex descriptor and mesh point property.
I have two major questions based on my understanding of how Point_set_3 and "dD Spatial Searching " work:
(1) Do I need an explicit Point_set_3::Index value to be able to retrieve a property from a property_map of a Point_set_3 object? My current understanding is yes, I need to have a Point_set_3::Index value because the property_map is indexed by Point_set_3::Index objects.
(2) When doing a search by "dD Spatial Searching", if I want to have a Point_set_3::Index as the search result, I need to use things like CGAL::Search_traits_adapter such that the search tree will store Point_set_3::Index for me.
Based on the above thoughts, I have composed a sample code, which currently has some compile errors. I also created a GitHub gist if that is more convenient.
The compile error is shown after the code. The error says that CGAL::Search_traits_adapter needs three template arguments but I only give it one. I cannot understand why it gives this error since there are three template arguments already. I failed to proceed any further and I think it's better to ask for help from experts. I am also uncertain if my usage of "tree" and "search" is correct in the reset of the code.
Can someone help me to resolve the compile error and identify any other errors regarding "tree" and "search"? Thank you so much!
========== Code begins. ==========
#include <array>
#include <iostream>
#include <CGAL/Point_set_3.h>
#include <CGAL/Orthogonal_k_neighbor_search.h>
#include <CGAL/Search_traits_3.h>
#include <CGAL/Search_traits_adapter.h>
template < typename CloudT, typename ColorMapT >
typename boost::property_traits<ColorMapT>::value_type nearest_color(
    const CloudT& cloud,
    const ColorMapT& color_map,
    const typename CloudT::Point_3& query) {
    typedef typename boost::property_traits<ColorMapT>::value_type Color_t;
    typedef typename CGAL::Kernel_traits<typename CloudT::Point_3>::Kernel CloudKernel_t;
    typedef CGAL::Search_traits_3<CloudKernel_t> SearchTraits_base_t;
    typedef CGAL::Search_traits_adapter<
        typename CloutT::Index,
        typename CloudT::Point_map,
        SearchTraits_base_t
    > SearchTraits_t;
    typedef CGAL::Orthogonal_k_neighbor_search<SearchTraits_t> CloudSearch_t;
    typedef CloudSearch_t::Tree  CloudSearchTree_t;
    typedef CloudSearchTree_t::Splitter  CloudSearchSplitter_t;
    typedef CloudSearch_t::Distance  CloudSearchDistance_t;
    // Set up a search tree.
    CloudSearchTree_t tree(
        cloud.begin(), cloud.end(),
        CloudSearchSplitter_t(),
        SearchTraits_t( cloud.point_map() ) );
    // Search.
    CloudSearchDistance_t distance( cloud.point_map() );
    CloudSearch_t search( tree, query, 1, 0, true, distance );
    const auto& neighbor_point_index = search.begin()->first;
    auto& cloud_neighbor_color = color_map[neighbor_point_index];
    return cloud_neighbor_color;
int main(int argc, char** argv) {
    std::cout << "Hello, test_point_set_nearest_neighbor! \n";
    typedef std::array< unsigned char, 3 > Color_t;
    typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel_t;
    typedef Kernel_t::Point_3 Point_t;
    typedef CGAL::Point_set_3<Point_t> PointSet_t;
    PointSet_t cloud;
    auto [ color_map, flag_added ] = cloud.add_property_map<Color_t>("color");
    // Populate the point cloud with color.
    // Omitted.
    nearest_color( cloud, color_map, Point_t(0, 0, 0) );
    return 0;
========== Code ends. ==========
========== Compile error begins. ==========
src/test_point_set_nearest_neighbor.cpp: In function ‘typename boost::property_traits<IndexMap>::value_type nearest_color(const CloudT&, const ColorMapT&, const typename CloudT::Point_3&)’:
/ws/src/shimizu_test_reconstruct_surface/src/test_point_set_nearest_neighbor.cpp:26:5: error: wrong number of template arguments (1, should be 3)
(Later error messages are omitted.)
========== Compile error ends. ==========
Thank you!
Yaoyu
