- To:
- Subject: Re: [cgal-discuss] Smooth surfaces at image boundary
- Date: Mon, 9 May 2022 10:43:50 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-data: A9a23:YNeCO6OaTn6Eym7vrR3AkcFynXyQoLVcMsEvi/4bfWQNrUorgj0Dz DAbCGCCMq3eYmf9LdogYYuzpkIBscPTnd9jQHM5pCpnJ55ogZqcVI7Bdi8cHAvLc5adFBo/h yk6QoOdRCzhZiaE/n9BCpC48T8kk/vgqoPUUIYoAAgoLeNfYHpn2EsLd9IR2NYy24DkW1PV4 7senuWGULOb824sWo4rw/nbwP9flKyaVOQw4zTSzdgS1LPvvyF94KA3fcldHFOkKmVgJdNWc s6YpF2PEsw1yD92Yj+tuu6TnkTn2dc+NyDW4pZdc/DKbhSvOkXe345jXMfwZ3u7hB2OuY1yy vptm6bvblwEOo7MnfwicytHRnQW0a1uoNcrIFC6sMCcxlfKNWHhxOUoBV1e0Y8wo7kpRzAIq qxecWtVBvyAr7reLLaTSuRogsMLNsTsLMUWphmMyBmAVqt9EMmaE80m4/d7zQZhuYNBFs3Qd swQN2RFMEn+WT52bwJ/5JUWx7712SKkKFW0smm9rqU+5y3fzRd6zaP2GMHEf8SDA8RThEeR4 Gzcl1kVGTkfNdCQwCCJtGihgf+JlD+TtJ8u+KOQ8dg3g1+85kIpVzpNeF+YofyhtW6MRIcKQ 6ALwRYGoa83/U2ta9DyWRykvXKJ1iLwvfIASoXWDyndkMLpDxal6nssE2cbOY193CMibW12h wbR9z/8LWY36NWopWShGqC8gR7aBMT4BWoDaSANVwdD+dTksMc6knojr+qP8obp17UZ+hmpk 1hmSRTSYJ1J1KY2O12Tpwyvvt5VjsGhovQJzgvWRHm5yQhyeZSoYYelgXCCs6sadNvAHgPQ4 yVV8yR70AzoJcHU/MBqaLVXdIxFG97ZYFUwfHY1RMN6q2jzk5JdVdEBu2olTKuWDir0UWSwP RCI4lg5CG57PHa2f6l6ecq2DcAry6WoGtHvVpjpgilmMvBMmPu81H80OSatM5bFzRB0ycnS+ P6zKq6RMJrtIfk5nGfuG7dBgNfGBEkWnAvueHwy9Dz/uZL2WZJfYe1t3IKmYr9r4aWajh/S9 toDZcKGxw8AAvfzZTmR+JJKdQIGKn0yBJbXrc1Ld7ffc1Q8Rzx7U6fckeE7Zohov6VJjeOUr HuzbUlVlQjkjnrdJATWN31uMeu9XZt2oX8hEzYrOFKkhyoqbYq1s/UFepwnO7A7rbQxwflxR vgDWsOBHvUWFmWZoWtAN8GlodU7JhqxhA+IMy60WxQFfsZtF17T59vpXgrz7y1SXCC5gs0z/ u+73QTBTJtfGglvAZqEaP+ryF/t73ERlPgrAhnNI9VccV/gtpJnLDy3h+Nue5MALhDKxz270 QeKAE5E9LeX/NJvqIHE1fKesoOkM+piBU4ETWPV2raBKnWI9GSUx4IdAv2DeirQVT6q9fz6N /lV1fz1LNYOgE1O79hnC79uwK9itcHjoaRWklZtEHnRNgn5D7JsLXCc0Y9Vu6pdgLZF4FPkV kWK89hcGLOIJMK8TA9PflV4NLzb2KFGgCTW4NQ0PF7+un198o2HZloObROCvypQceluO4Q/z OZ85sNPs16jigAnO8qthzxP8zjeNWQJVqgqu/n22mMwZtbHHr2DXXDdNsMyyJSOZ9pFKEVsO DKTlOzLm9ywA6YEn2UbTRDwMSh13PzieyymCHcYKlOZ3NPZ7hPy9AME6iw5F2y50T0eu9+e+ QFX24ldP6iJ73FhmKCvmoxq9x5pXHWkx6A697fFeKA1gaVluqwh4VDR4dqwwX0=
- Ironport-hdrordr: A9a23:E+Cxd679IVJ6S5bZHwPXwNnXdLJyesId70hD6qkDc3Jom62j/f xG88526faZskdzZJhko6HkBEDiexzhHPxOjLX5VI3KNGLbUSmTTL2KhrGSoQEIdReeytJg
- Ironport-phdr: A9a23:ihTblRXqDQW/adcMu4TTxIksfZPV8KxJUTF92vMcY1JmTK2v8tzYM VDF4r011RmVB96dsKMP07ae8/i5HzBau9DZ6DFKWacPfidNsd8RkQ0kDZzNImzAB9muURYHG t9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3wOgVvO+v6BJPZgdip2OCu4Z3TZBhDiCagbb9oI xi6swvcutMYjIZmJao91hTEqWZMd+hK2G9kP12ekwji6suq4JJv7yFcsO89+sBdVqn3Y742R qFCAjQ8NGA16szrtR3dQgaK+3ARTGYYnAdWDgbc9B31UYv/vSX8tupmxSmVJtb2QqwuWTSj9 KhkVhnlgzoaOjEj8WHXjstwjL9HoB+kuhdyzZLYbJ2TOfFjeK7WYNEUSndbXstJSyNPAY2yY IQRAeoPPehWsovyqkALrReiHwShHv/jxiNKi3LwwKY00/4hEQbD3AE4H9IBrnDUrNHyNKoJS +C60q7IzDrZY/xMxTfw7pXDfR89r/+WR71wbdbRxlc1FwPDllidq47oMi2U2+oCvWWX8eRuW OCuhmI7tg1/ojihy8guh4TGm48YxU3J+CdkzYg7KtC1TEF2bcO5HZZNuS+WKY97T8U/SG9mv yY6z6cJuZ+9fCUS1JsnyATQa/idf4iP+BLjW+CcKip7inJ9YL+zmhS//Em6xuD4TMW50lVHo jBYntTCqnwA0QHY5NKdRftn5Eih3C6C1wDN5eFAJkA5ja/bK588zb4/jJUTq1nMEjXsmEroi 6+XeV8o9fK06+j/Y7XmoIGTN5Nshw3jMKkjm9azDOAiPgUMXGWX4/mw2bP/8UHhRbVFlPw2k q3XsJDAIsQbo7a0Aw9L3YYn7xa/CCyr0M4GknkAI1NJYgiIj5TxN1HIO//3Fe2/jEi0kDd32 /DGOaXsDojVInjZjLjhZap961JbyAcr0d9f6IhbCrUYLP3uW0/xr8DXDgIiMwyv2OvnE9V81 oYGWW2VGKOZMaXSsUWJ5u01OeWMapUV637BLK0u6PfqyHM4glQAZrKB3J0NaXn+EO41DV+eZ C/sj9MFFk8Qsw0uCuX22w7KaiJae3vnB/F03To8Eo/zVe8rJ6ioib2Fh2KgG4FOI3tBEhaKG GvpcIONX7ENbjiTK4lviG9MTqCvHqkm0xzmrwrm0/x/NOOB+iAcsZXLztVy96vaiUJ67iR6W vyUyHrFVGRohiUNTj4y0rp4pBl9x1OH1oBijvtIU9VPtLtSSglvE5nawqRhDszqHALMetDcU FG9XtCvGi08VPo0wtMBalxxXc+viQCF1jbC76Y9sbuNCdR096vd2yO0PMNh0zPd07FniVA6Q 8xJPGngh6hl9gGVCZSb20Oe372nc6gRxkuvvC+K0HaOsUdEUQVxTbSNXHYRYVHTpMj44UWKR qGnCLAuOA9MgcCYLa4CZtrshFRADPDtXbaWK2K8n2O3LQyFwaPKZZarM2QR0SPBCVQVxhgJ9 CXOPgw/CyG95mPGWWUxSxS+JRy8t7Al8CDeLAd81QyBYkx/2qDg/xcUgafZUPYPxvcfvz9nr TxoHVG71taQCtyapgMncr8PBLF1qFpBy2/dsBRwe5K6KKU3zF4TdwBwl1nj0AUxA5kKwoA66 WgnygZ/M/fS0F5FczSwx533KvveNiOhmXLnI76T0VbY3tGM/64J4/ltsFTvsjaiEU86+mlm2 d1Yu5eFzq3DFxFaEZf4U0JssgN/u6mfeS4loYXdyXxrN6Cw9D7EwdMgQuU/mF6seNJWMaXME wGXcYVSB8WqLOsCgVWuflQNIKhe+bU1MMWva/adkPf0YqAx2m32yz0cuMh0yQqU+jB5S/LU0 ppN2Pye0gadFlKexB+gvs3xhYFYdGQXF2u7xzLjAd0ZbalzcIAXTGa2dpTomJMvwcG9HScDr A3GZRtOwsKidBuMYkao2ARR0R9Sunm7gW6jyCQylTg1r62Z1SiIwuL4dRNBNHQYIQsqxVrqP 4WwiMgXGUayaA183huo4UL977JWo7Q5JnWZEg9YOjP7KW1vSP76treGZ8ln8p4voWNeTK7vB DLSAq64qBwc3ST5GmJYzz1ubDCmtKLymBligX6cJnJ+/zLJPNt9zhDF6JnAVOZci3AYETJgh 2CdVT3ed5G5uM+ZnJDZvqWiWnK9A9dNJDLzw9rI9yLzpmh6SVi2m/T58jH+OS491yKzl9xjV CGT6Q35fpGuzKOid+RuYkhvAlb4rct8AIB31IUq1tkW3jABi5OZ8GBi8y+7OMhH2a/4cHsGR CIai9/T7g//3UR/L3WPj4vnX3SZy8FlapG0eGQTki466slLDu+T4tkm1WNtpUGkqAvKffVnt jIcxfQn8nJcmewOqEwk0mTVA7wfG1VZIT25lxmM6IPbzu0fb2KufL6skUtmyIn+UvfT5F4MH i+iIsRHf2c49Mh0PVPS3Wem74jlfIKVdtcPrliPlA+GieFJKZU3n/5MhCx9OGu7s2d2roxzx RFow5y+u5CKbmt3+6fsSB5VMjnyT9ke/SGrhLoUzaP0l8i/W45sHDkGRs6iVfWzDDcbrujqL S6LETEzo22XX6DSGh/Z4Vss/BetW9i7cnqQInce19BrQhKQcVdejA4jVzI/hpclFwquyaQJk W985zwe70T07AFBzfIuPgWtCg83QS+yZzAkDpGDfkI+Bu5q/UrSIYqX8rAqdxw=
- Ironport-sdr: QZ9tYMxbVfou0sqDZ0qORy8Q82sofXycWYW3htcOTIA2HhX+GeXWdnVvDy3NzantWRyoThYjmJ H+E/KN9ktqZijL6sKYYOf3GqFiwW3UDQvjWjV33jCTgK4LMINqmLspYRqjLdr/M3OG+MdfoJL0 TPxm9I/X7yObi1YHSaZGUWt4qc+54eb+rnozD7TSlYd7o8gNUzt0K/JpSTp91rlP0W8aERPr7y jwpQkClgG9GjwgSeju1NvBm39scVQw0nGoU9qy6kL6/yrSc2sqVX4ib7KycuuigJXERDHvWyGk Srco2Xd7iHRGig+yyyvUJ0Nx
Hello,
sure! Attached is an example source code and the resulting file for the 420 example.
I would have expected, that all nodes on the bounding surfaces are either at x/y/z 0 or 100 (as it is for the edges) but instead they appear roughly at 0 or 100 +-0.05.
It seems to correlate with the relative_error_bound, however I can only make the error smaller but not go away completely. (The attached file is generated with 1e-3)
Best,
Sebastian
On 09.05.22 09:23, Sebastien Loriot ( via cgal-discuss Mailing List) wrote:
Hello,
could you share a minimal example showing the problem?
Thanks,
Sebastien.
On 5/7/22 13:37, Sebastian Bachmann ( via cgal-discuss Mailing List) wrote:Hello,
No one has an idea? Is it not somehow possible to restrict nodes onto a surface? I.e. if I have the polyline of the surface's boundary, can I specify that all nodes must be on that surface?
For now I have written a function to go over all nodes and check if they are near such a boundary face and then "pull" the nodes onto that surface. However, there are certain edge cases were this then yields collapsed triangles etc. Thus, solving this during meshing would be a great enhancement.
Best,
Sebastian
On 25.04.2022 07:16, Sebastian Bachmann ( via cgal-discuss Mailing List) wrote:Hello,
I created an image meshing tool, similar to the one given here in this example code: https://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_3D_image_with_features_8cpp-example.html with the only difference, that I extract the surface elements and not write the full 3D mesh.
I noticed, that on the image boundary, the vertices would be not exactly on the face but roughly +- the relative error bound given in create_labeled_image_mesh_domain. For examples, nodes on the xy plane at z=0 are not on z=0 but for example -0.01 to 0.01. While the protected polylines are exact and have always z=0.
I created for example a mesh from the 420.inr example with the same meshing criteria as given in the example and can see that behaviour there.
While you can control the maximal deviation using the relative error bound, there will always be some deviation. And if I set the relative error bound too low, it seems the meshing never finishes.
I wonder now, if it is possible to constraint the mesh (similar to the 1d polylines), such that the vertices for facets on the image boundary, are always exactly on the image boundary?
Best,
Sebastian
#include <vector> #include <iostream> #include <CGAL/Mesh_triangulation_3.h> #include <CGAL/Mesh_complex_3_in_triangulation_3.h> #include <CGAL/Mesh_criteria_3.h> #include <CGAL/make_mesh_3.h> #include <CGAL/Image_3.h> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Mesh_domain_with_polyline_features_3.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/Labeled_mesh_domain_3.h> typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Labeled_mesh_domain_3<K> Image_domain; typedef CGAL::Mesh_domain_with_polyline_features_3<Image_domain> Mesh_domain; #ifdef CGAL_CONCURRENT_MESH_3 typedef CGAL::Parallel_tag Concurrency_tag; #else typedef CGAL::Sequential_tag Concurrency_tag; #endif // Triangulation typedef CGAL::Mesh_triangulation_3<Mesh_domain,CGAL::Default,Concurrency_tag>::type Tr; typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3; // Criteria typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria; typedef K::Point_3 Point_3; typedef unsigned char Word_type; using namespace CGAL::parameters; #include <CGAL/Mesh_3/polylines_to_protect.h> // undocumented header int main(int argc, char* argv[]) { const std::string fname = (argc>1)?argv[1]:CGAL::data_file_path("images/420.inr"); // Loads image CGAL::Image_3 image; if(!image.read(fname)){ std::cerr << "Error: Cannot read file " << fname << std::endl; return EXIT_FAILURE; } // Domain double tol = (argc>2)?std::stod(argv[2]):1e-3; Mesh_domain domain = Mesh_domain::create_labeled_image_mesh_domain(image, relative_error_bound=tol); std::vector<std::vector<Point_3> > polylines_on_bbox; CGAL::polylines_to_protect<Point_3, Word_type>(image, polylines_on_bbox); domain.add_features(polylines_on_bbox.begin(), polylines_on_bbox.end()); Mesh_criteria criteria(edge_size=6, facet_angle=30, facet_size=6, facet_distance=4, cell_radius_edge_ratio=3, cell_size=8); // Meshing C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria); // Extract surface CGAL::Polyhedron_3<K> poly; CGAL::facets_in_complex_3_to_triangle_mesh(c3t3, poly); std::ofstream mout("420_surface.off"); mout << poly; mout.close(); return 0; }
420_surface.off
Description: object/oogl
- Re: [cgal-discuss] Smooth surfaces at image boundary, Sebastian Bachmann, 05/07/2022
- Re: [cgal-discuss] Smooth surfaces at image boundary, Sebastien Loriot, 05/09/2022
- Re: [cgal-discuss] Smooth surfaces at image boundary, hello, 05/09/2022
- Re: [cgal-discuss] Smooth surfaces at image boundary, Sebastian Bachmann, 05/09/2022
- Re: [cgal-discuss] Smooth surfaces at image boundary, Sebastien Loriot, 05/10/2022
- Re: [cgal-discuss] Smooth surfaces at image boundary, Sebastian Bachmann, 05/10/2022
