cgal-discuss - Re: [cgal-discuss] circle-circle algorithm intersection
  • To: Alessio Mochi <>
  • Subject: Re: [cgal-discuss] circle-circle algorithm intersection
  • Date: Sat, 4 Nov 2023 01:00:46 +0100 (CET)
  • Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail ; dmarc=fail (p=none dis=none) d=inria.fr
On Fri, 3 Nov 2023, Alessio Mochi wrote:
// first circle with center (circle1_x, circle1_y) and radius ray1
Circle_2k c1(Point_2k(circle1_x, circle1_y), ray1);
If you check the documentation, the constructor takes as argument the **squared** radius. Could this be the issue?
Marc Glisse
