- From: Pierre CASTERAN <Pierre.Casteran AT labri.u-bordeaux.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Difficulties with Guarded
- Date: Wed, 28 Jan 1998 13:52:05 +0100 (MET)
hello, i have some problems in building some theory of sequences
(possibly finite streams).
I cannot prove the theorem :
Theorem I_nth : (s:Sequence)(infinite s)->(n:nat)(nth_defined s n).
telling that if a sequence is infinite, we can define its n-th element
for each n .
I assume that the problem comes from the guarding conditions,
(only constructors above the recursive call) but is there some
classical solution ?
Thank you in advance,
Pierre
(* was "Streams.v" *)
(* Modified to allow finite sequences *)
(* by P. Casteran *)
Section Sequences.
Variable A : Set.
(* The set of (possibly finite) streams : definition *)
CoInductive Set Sequence := Empty : Sequence |
Cons : A->Sequence->Sequence.
CoInductive infinite : Sequence -> Prop :=
Cons_i : (a:A)(s:Sequence)(infinite s) ->(infinite (Cons a s)).
(* (is_nth a n s) means "a is at the n th position in sequence s" *)
Inductive is_nth[a:A]: nat->Sequence->Prop :=
is_nth_O : (s:Sequence)(is_nth a O (Cons a s))
| is_nth_S : (n:nat)(b:A)(s:Sequence)(is_nth a n s)->
(is_nth a (S n) (Cons b s)).
Inductive nth_defined[s:Sequence;n:nat] : Prop :=
nth_defined_intro : (a:A)(is_nth a n s)->(nth_defined s n).
(* Cofix naturally doesn't work ! *)
(* may be use an auxiliary predicate? *)
CoInductive AUX : Sequence ->Prop :=
AUX_i : (a:A)(s:Sequence )
(AUX s) ->
((n:nat)(nth_defined s n)) ->
(AUX (Cons a s)).
Remark triv: (s:Sequence)(AUX s)->(n:nat)(nth_defined s n).
Intros s H.
Inversion H.
Induction n.
Exists a;Auto.
Constructor 1.
Intros.
Case (H1 n0).
Intros.
Exists a0.
Constructor 2.
Auto.
Qed.
Remark DontWork : (s:Sequence)(infinite s) -> (AUX s).
Cofix.
Destruct s.
Intro.
Inversion H.
Intros.
Split.
Apply DontWork.
Inversion H.
Auto.
Intro;Apply triv.
Guarded.
Apply DontWork.
Guarded. (* NO !!!! *)
- Difficulties with Guarded, Pierre CASTERAN
- <Possible follow-ups>
- Re:Difficulties with Guarded, Eduardo Gimenez
