coq-club - Re: big sections
Re: big sections
chronological Thread
  • From: Jean-Christophe Filliatre <Jean-Christophe.Filliatre AT lri.fr>
  • To: Loic.Pottier AT sophia.inria.fr
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: big sections
  • Date: Wed, 11 Mar 1998 10:21:33 +0100
> I dont understand the following behaviour of Coq (V6.2 beta):
> Load test1.
> OK the type list is generalized with A.
> But with a Require, this is no more true:
> Why?
When "Variable" is not inside a section, it is equivalent to
"Parameter". So when you compile test1, A is a parameter, and then
when you do "Require test1" you have a parameter A, which will not be
discharged when closing the section because it is not a variable.
When doing "Load test1", it is like an expansion of the contents of
the file test1, and consequently "Variable" is now a real variable,
which will be discharged when closing the section.
> This implies that a  section cannot be  splitted in several modules,
> which is a big problem for me:
Indeed, it is not possible.
A possible solution is to re-instantiate you generalized definitions
in other modules on other variables, like this :
file1 : Section S.
        Variable A:T.
        Definition foo := ...
        Theorem bar : ...
        End S.
file2 : Require file1.
        Section S.
        Variable A:T.
        Local foo := (foo A).
        Local bar := (bar A).
        Definition gee := ...
        End S.
etc.
I don't really know of it is a good solution in practice...
Jean-Christophe FILLIATRE
mailto:Jean-Christophe.Filliatre AT lri.fr
  http://www.lri.fr/~filliatr
