coq-club - to be or not to be infinite.
chronological Thread
  • From: Pierre CASTERAN <Pierre.Casteran AT labri.u-bordeaux.fr>
  • To: coq-club AT pauillac.inria.fr
  • Subject: to be or not to be infinite.
  • Date: Fri, 27 Mar 1998 09:58:36 +0100 (MET)
 Hello,
 Just a question:
 You may find below a little theory of sequences (finite or infinite).
 I had no problem to prove (in a classical framework) the disjunction :
 (s:(sequence A))(finite A s) \/ (infinite A s).
 But I failed to do that in the intuitionnistic framework.
 May i infer from my personal failure that the frontier between
 intuitionnist and classical deduction passes by this point ?
 Best regards,
Pierre
(* adapted from the "Stream" package *)
Section Sequences.
 Variable A :Set.
 CoInductive Set sequence := Empty : sequence
                           | Seq : A->sequence->sequence.
 Definition rest  :=
   [s:sequence]Cases s of Empty => Empty
                      | (Seq a s') => s'
               end.
 Definition head : sequence -> (Exc A) :=
  [x:sequence]Cases x of Empty => (error A)
                      | (Seq a s) => (value A a)
               end.
End Sequences.
Syntactic Definition seq := (Seq ?).
Syntactic Definition hd   := (head ?).
Syntactic Definition rst   := (rest ?).
Syntactic Definition empty := (Empty ?).
Section Basic_predicates.
 Variable A:Set.
 Inductive finite : (sequence A) -> Prop :=
   Empty_f : (finite empty)
 | Seq_f :  (a:A)(s:(sequence A))(finite s) ->
                            (finite (seq a s)).
 CoInductive infinite : (sequence A) -> Prop :=
  Seq_i : (a:A)(s:(sequence A))(infinite s) ->(infinite (seq a s)).
End Basic_predicates.
Section Basic_Lemmas.
Variable A:Set.
(* Finite/Infinite *)
(* Agradezco a Eduardo por los dos siguientes lemas *)
Lemma emptyNoInfinite : (s:(sequence A))(infinite ? s)->~s=empty.
Proof.
 Intros s H.
 Inversion H.
 Discriminate.
Qed.
Lemma restOfInfinite : (s:(sequence A))(infinite ? s)->(infinite ? (rst s)).
Proof.
 Intros s H.
 Inversion H.
 Assumption.
Qed.
Lemma finite_not_infinite:(s:(sequence A))(finite ? s)->~(infinite ? s).
Proof.
 Induction 1.
 Red;Intro H.
 Inversion H0;Discriminate.
 Intros.
 Red;Intro.
 Apply H1.
 Replace s0 with (rst (seq a s0)).
 Apply restOfInfinite;Auto.
 Simpl;Auto.
Qed.
Lemma not_finite_infinite:(s:(sequence A))~(finite ? s)->(infinite ? s).
Proof.
 Cofix.
 Destruct s.
 Intro;Absurd (finite A empty);Auto.
 Left.
 Intros.
 Split.
 Guarded.
 Apply not_finite_infinite.
 Guarded.
 Red;Intro;Apply H.
 Right;Auto.
Qed.
Section Finite_or_infinite.
 Hypothesis tex :(P:Prop)P \/ ~P.
 Lemma finite_or_infinite: (s:(sequence A))(finite ? s) \/ (infinite ? s).
 Proof.
   Intro s;Case(tex (infinite ? s));[Auto|Intro].
   Left.
   Case (tex (finite ? s));[Auto|Intro].
   Absurd (infinite ? s).
   Auto.
   Apply not_finite_infinite;Auto.
 Qed.
End Finite_or_infinite.
Lemma intuitionnistic_version:
Abort.
End Basic_Lemmas.
