coq-club - Transparencies
Transparencies
chronological Thread
  • To: COQ mailing list <coq-club AT pauillac.inria.fr>
  • Subject: Transparencies
  • Date: Wed, 13 May 1998 16:54:16 +0200 (MET DST)
I have some problem in the use of transparent and opaque constants.
I have this proof of decidability of gt:
Require Export Arith.
Require Export Compare_dec.
Lemma gt_decidable : (m : nat){(gt n m)}+{~(gt n m)}.
Intro m.
Case (le_gt_dec n m).
Intro H.
Right .
Apply (le_not_gt n m).
Assumption.
Intro.
Left ; Assumption.
Qed.
I need gt_decidable to be completely transparent, because I will use it
to define types by cases on (gt_decidable n m), and to have that these
types are equal to the types that I expect the actual computation of
which of the two disjucts holds is necessary.
Since the proof uses also le_not_gt, whose proof in turn uses le_lt_dec,
I need to declare all of them as transparent:
Transparent le_lt_dec.
Transparent le_gt_dec.
Transparent gt_decidable.
But I would like le_lt_dec and le_gt_dec to remain opaque. And maybe also
to have two version of the decidability of gt, one transparent and one
opaque.
In other words I don't want to declare le_lt_dec, le_gt_dec, gt_decidable
as transparent, but rather to define a new constant
gt_dec = gt_decidable with le_lt_dec and gt_decidable unfolded
The only way I found to do this is manually: first I found the needed
term by giving the transparency commands and
Eval Compute in gt_decidable
and so getting an orrible expression, and then defining
Definition gt_dec := orrible expression.
Is there some nicer way to do this?
Thank you,
  Venanzio
Venanzio Capretta
University of Nijmegen
Faculty of Mathematics
       and Informatics
the Nederlands
tel.: +31-24-3652647
