- From: Jean-Francois Monin <JeanFrancois.Monin AT cnet.francetelecom.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: hiding Sets
- Date: Fri, 12 Jun 1998 10:25:24 +0200 (MET DST)
Hello,
I have a Set ordm and functions like f: ordm -> ordm, and introduce
Inductive ordp : Prop := Hide : ordm -> ordp.
Scheme ordp_indd := Induction for ordp Sort Prop.
In this way it is possible to
would work on some family (A x) with x:ordp and to
build e.g. ff : (x:ordp) (A x) -> (A (f x)).
Case analysis on the content of x is forbidden at the Set level.
Extracting the informative contents of ff yields a function of type
A->A, as desired. (If ff had the type (x:ordm) (A x) -> (A (f x)),
extraction would inhabit ordm->A->A, though the first argument is not
used.)
I agree that it is not very convenient, because counterparts of
theorems on ordm have to be proved on ordm. As far as I remember, this
should be settled with a new approach of extraction to be implemented.
However it should at least be feasible. At the moment I need the
following axiom.
Axiom ax_eqP_eq :
(x,y:ordm) (eqP ordm (Hide x) (Hide y)) -> x=y.
Is this axiom dangerous ?
-- Jean-Francois.
- hiding Sets, Jean-Francois Monin
- Re: hiding Sets, Christine Paulin
