- To: coq-club AT pauillac.inria.fr
- Subject: skipping the proofs
- Date: Thu, 4 Feb 1999 14:36:30 GMT
> The gallina file .g is just the version of the vernacular file .v without
> the proofs. Thus, you have the whole development (definitions, syntax,
> lemmas, etc.) but without the hundreds lines of proof.
Sometimes I want to load a .v file, skipping the proofs and treating
the lemmas as axioms. Coq supports the compiled .vi file for this
purpose, but then you must maintain the .vi files up-to-date ....
Here is a suggestion for a different approach: have a top-level switch
that tells whether or not to load the proofs from a .v file. If
proofs are not being loaded, then Lemmas are treated as Axioms.
Further, a source specification file, i.e. a .v file without proofs,
could be loaded in this no-proof mode, without changing "Lemma" to
"Axiom".
BTW, the switch could also work for loading .vo files, so there would
no longer be a need for the .vi format at all. (This might require a
change in .vo format, to distinguish between definitions and proved
lemmas.) Such a switch is dynamically set and reset, giving more
flexibility than .vi files.
Best regards,
Randy
- skipping the proofs, Randy Pollack
- Re: skipping the proofs,
Jean-Christophe Filliatre
- Re: skipping the proofs, Randy Pollack
